![]() | Home > Dealership & Service Feedback > MDRS Autos |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 420 ![]() ![]() ![]() |
Looks to me as the drivers side glow plug wiring has not been reconnected at the multiplug on top of the inlet manifold or all 4 glowplugs have not been connected back up, more likely the multiplug though in my opinion.
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Hi thanks for the reply I’ve sorted the glow plugs they were not connected 🙄 no it went in for broken cam chain then it needed new cams on the drivers side the passenger side wasn’t touched and they shouldn’t have touched any of the injectors that side from my knowledge so it shouldn’t have had an injector replaced but who knows as I haven’t had a full breakdown of works or a vat receipt 2012 Range Rover Westminster 4.4 TDV8
They don't seem to have done a very good job!! I think you're bill is a bit steep for a chain, hopefully guides and cams, I just rebuilt my complete engine with all genuine parts and came out much the same as yours!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1348 ![]() ![]() ![]() |
When you look at their facebook page they seem to turn things round very quickly and perform miracles!
Well a little update we had a low coolant warning today then when I got home there was a drip of coolant from the chassis rail, looks like it’s coming down from the back of the engine but decided to take the sump trays off, half the nuts were missing then when I dropped the sump there were six Tray bolts in there ffs 🤦 a few broken bolts as well, no coolant from the front but oil down the side either from power steering or turbo but the best bit they hadn’t even put the four front sump bolts in 😳
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3335 ![]() ![]() ![]() |
Did you pay by credit card for the works done? If so, begin the process of a section 75 chargeback as the work they’ve done obviously isn’t fit for purpose.
That’s what we’re looking at doing I’ve asked for vat receipts a breakdown of works done and proof of the cams fitted and new cam chains but nothing the list of things they haven’t done is growing, not sure how to start the process but I’m going to get all the evidence dates etc just to back it all up 2012 Range Rover Westminster 4.4 TDV8
I'd check for oil leaks around the oil pump to sump mating surfaces as to replace a chain they would need to remove the oil pump, which should be done by firstly removing the sump. If they've cut a few corners and left the sump on, then the sump gasket won't have been changed, and as the oil pump mates to the sump gasket its quite likely the gasket has been compromised.
They were meant to replace the oil pump as part of the job, but didn’t there is a thin film of oil on the front of the engine but I can’t see where it’s coming from, any ideas what length bolts are required for the sump or at least a part no so I can order some I’m meant to be going to north wales on Wednesday ffs for the week 2012 Range Rover Westminster 4.4 TDV8
Think you need M8 X 25mm,Screw Oil Pan, diagram callout HS2, part no. 4540794 @ £1.21 each.
Hi 4RRS yes there the ones thank you I’ll see if my dealers have them now to trace the coolant leak at the back drivers side of the engine 2012 Range Rover Westminster 4.4 TDV8
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1171 ![]() ![]() ![]() |
What a bunch of cowboys who need to be avoided. |
Rokbe Member Since: 29 Mar 2024 Location: Andorra Posts: 1 ![]() ![]() |
MDRS. Where to start
Wish I’d have found this out earlier they are a bunch of cowboys time to talk to the card issuers to get my money back the more I work on the car the more damage I find 2012 Range Rover Westminster 4.4 TDV8
