Home > Technical (L322) > 4.4 SDV8 /TDV8 Engine Failures? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
Not disputing that oil dilution is likely contributing to bearing failure, after monitoring oil pressures and seeing oil pressures prior to the oil getting up to the temperature at least double that of when the oil is warm, I suspect cold starts are playing their part in causing accelerated wear due to inadequate lubrication especially if combined with other than gentle driving until warm. Even at 20 degC overnight here ATM, initial idle pressure is 35 psi but only 12 psi once up to temperature and initially over 50 psi at 1200 rpm but only 15-16 psi once warm. My suspicion is that there could initially be inadequate bearing lubrication due to insufficient oil until the oil is at its hot viscocity where it flows much more readily, as allowed for by the engine designers.
27th Mar 2024 9:20pm |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 114 |
How can you tell when your car is having a dpf regen? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
27th Mar 2024 9:33pm |
4RRS Member Since: 13 Apr 2022 Location: Stafford Posts: 119 |
I rather sadly watch my Gap IID tool like a hawk. Having an Android 12" head unit helps as I run the IID app on that to save being distracted looking at my phone based app. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
27th Mar 2024 9:38pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2734 |
In that case oil dilution would help with cold starts by making the oil even thinner and flow faster offset somwhat by it's lower film strength. last winter I was amazed how far behind the oil temps were compared to coolant temps and on a steady 70mph M-way it took 30mins longer for the oil to get up to operating temps than the coolant and probably 45mins total from a cold start. I always drive gently for the first 45mins no matter what and am worried when people suggest 'booting it' to clear the DPF or 2nd turbo oil accumulation by just relying on the coolant guage. 2012 TDV8 Vogue (L322) |
28th Mar 2024 8:53am |
That's a big discrepancy in warm-up time when they're both circulating in the same block. |
28th Mar 2024 9:12am |
Yes but the coolant is also being heated by the FBH in winter and thus coolant temp is not the engine temp. Oil temperature is the crucial measure of when an engine is up to 'operating temps' and thus able to safley be run under load. 2012 TDV8 Vogue (L322) |
28th Mar 2024 9:21am |
OK, heat from a source other than the combustion chamber and the sump could be providing extra cooling too.
28th Mar 2024 9:31am |
If 65deg C is 'operating temps' then the lag is much less. 2012 TDV8 Vogue (L322) |
28th Mar 2024 10:03am |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 83 |
How many people that talk about fuel dilution can show used oil analysis reports (UOA's) showing the actual measured fuel dilution?
28th Mar 2024 10:31am |
I'll check mine's 65degC pressures when I remember to connect the IIDtool on a morning run to get the mail. |
28th Mar 2024 11:05am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 377 |
Hi Graeme, Those warm oil pressure readings seem low? I don't know what the actual spec is for a 4.4 TDV8 so could be talking out of my posterior, but 15-16psi at 1200rpm, seems very low to me? With the ZF 8 speed box, 70mph on a motorway is achieved at little more than 1400rpm, I can't see the oil pressure rising much higher with just another couple of hundred rpm or so? If I had a traditional oil pressure gauge marked from 0-100psi (which they often are), I'd be very worried if the oil pressure was under 20psi at motorway speeds! I know that general opinion with the Disco boys is that spun bearings / snapped cranks in the SD/TDV6 engine are highly likely to be a result of low oil pressure due to oil pump wear. Additionally, the V6 crank design, journal count and big end lubrication is totally compromised as PSA wanted a 'shorter' engine that could also be mounted transversely in a car. Their thoughts are that the SD/TDV6 being coupled to the ZF 8 speed box, giving low cruising RPM, together with a worn oil pump is one of the primary causes of spun bearings. And because the crank in the V6 oil burner is a bad design (AKA made of chocolate), it can snap when a bearing seizes. I know they're completely different engines, with the TDV8 coming from Ford, but I wonder if low oil pressures linked to low cruising rpm's and perhaps also a worn oil pump isn't also a factor with TDV8 engine failures? Perhaps a car with 'mainly motorway miles' isn't such a good thing after all! 1992 RR Classic 3.9 efi Vogue =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
28th Mar 2024 11:23am |
I very recently replaced mine's pump when I saw such low pressures after seeing quite high pressures at start-up in our late summer temperatures when I took the opportunity to fit a pressure sender while replacing a leaking radiator, done because of the unexplained bearing failures in the TD/SDV8. However the new genuine pump didn't produce any more pressure than the original that had done 180K kms. Hot specs are idle 12 psi (min 9) and 35 psi at 3000 rpm (min 29 psi) at 65 degC, which mine has achieved at its hot temps of 85-88 degC each time I've checked it.
28th Mar 2024 11:57am |
Oil pressure is just a measure of resistance to flow hence why it changes with viscosity and temperature. It's only low if it's below the manufacturers spec at a particular temp and RPM. Seemingly low pressure can actualy mean good flow and vice versa 2012 TDV8 Vogue (L322) |
28th Mar 2024 12:44pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 258 |
Indeed, as above.
28th Mar 2024 1:41pm |
