![]() | Home > Technical (L322) > 4.4 SDV8 /TDV8 Engine Failures? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 546 ![]() ![]() |
But are the specs sufficient? They could be driven by a need to pass emissions / economy targets specified by the legislators and marketing people! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
The write-up in the WSM refers to adequate pressure.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
The oil pump bypass opens at 4.5 bar.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 844 ![]() ![]() |
There is a thread on this forum….how many miles on your FFRR. There are plenty of examples with >100k miles
Apparently not that rare, that's why I started this post. It certainly wouldn't stop me buying another one, I agree it's a very good engine and extremely reliable. But I just wanted to understand why there's been so many recent posts of total engine failure (i.e. within the last 6 months or so): Here are some recent posts from this forum alone: https://www.fullfatrr.com/forum/topic68615.html https://www.fullfatrr.com/forum/post670681.html https://www.fullfatrr.com/forum/topic68014.html And three not-so recent, but within last couple of years or so: https://www.fullfatrr.com/forum/post621421.html https://www.fullfatrr.com/forum/topic64323.html https://www.fullfatrr.com/forum/post583088.html I found the above after a fairly quick 10 min search (using Google, the forum's own search engine is a mystery to me), I'm sure there are more examples here and of course on other sites / forums. Having collated the above links, together with the excellent & helpful responses above, the answer is starting to appear for me, failures are likely to be: * Past or present oil cooler failure with coolant getting into the oil & left unchecked - may have happened during a previous ownership * Oil dilution from incomplete active DPF regens * Poor servicing / incorrect grade of oil being used - again, likely by a previous owner perhaps? Or a fabricated service history from a dodgy seller hiding a poorly serviced vehicle. * MY16.5 cars onwards with Ad-Blue seem more susceptible to con-rod bearing issues? * Possibly an engine design issue - 8 speed box, low cruising RPM's together with low pressure oil pump - I still think this is a possibility, especially if towing in 8th gear and loading up the crank at low RPM's. So it's largely down to the same causes as any other modern engine failure. But there are some anomalies here. Such as the 80K L405 with full history, etc. But, I guess we never know how a 2nd hand car has been driven / serviced, etc by its previous owner(s)! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3298 ![]() ![]() ![]() |
I think it would be difficult to find any forum on cars where engines have a 100% non fail record.
D3Jon
Ooh, very good observation! All but one are SDV8's. I never picked up on that, so obvious when you stand back a little! ![]() I was grouping them together as a TD/SDV8 as to me, they're the same engine. Perhaps not though, or it's something in the packaging of the engine in the L405! If it is internal to the engine, what's changed with the SDV8 I wonder (EDIT -> other than the slight power hike and turbo drain mod)? An even lower pressure oil pump to meet emission targets? This is exactly why I started this thread! ![]() J 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
It would be easy enough to compare the oil pressure tests in the respective workshop manuals. Same engine internals will respond differently in terms of stress and wear to different ECU gearbox and engine mapping. Like I said I 'think' my L322 revs too high under load for the torque capability of the engine at low revs but this may be entirely appropriate for reducing undue bearing load at low rpm/ low oil flow rates? Additionally we know the ECU holds higher revs during warm-up to speed up engine temp rise but this has always puzzled me as it's load not revs that creates internal engine heat so maybe safe oilflow to the bearings is the real reason? I can however imagine customer feedback or marketing to want the lowest possible revs for any gear to emphasis the effortless quiet quality of the power unit. 2012 TDV8 Vogue (L322) |
D3Jon
20bhp at high revs is easy to acheive through mapping and is insignificant as a load on the engine. I doubt it runs hotter to lower emissions as the purpose of the EGR system is to reduce combustion temperatures to reduce NOX emissions. The emissions reduction of NOX on the Euro 6 version of the SDV8 is done by the adblue injection in the exhaust system. Difficult to imagine after so many years of use and develpment that they messed up the DPF regen strategy and worsened oil dilution but at the same time marketing may well have been pushing for longer service intervals as a selling point. 2012 TDV8 Vogue (L322) |
The latest oil pump part number fitted to my L322 did not change oil pressure at all, so no change in pressure menas no change in capacity. I noted that the rotor widths were the same. |
If only the engine manufacturers added an extra injector into the exhaust manifold / downpipe (post cylinder head & pre DPF) and injected the extra fuel THERE for DPF regen purposes, we wouldn't have all this oil dilution mess!
That's interesting Graeme, so no updated parts like there is for the TDV6, would surely mean there's no problem with the oil pump on the TDV8! Which has to be good news! ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
