Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil
Page 2 of 6 <123456>
Mikey
Strictly speaking, C* spec is largely irrelevant. You need an oil equivalent to STJLR.03.5005 to meet the required specs (2.7/3.0/3.6/4.4 with DPF) Thumbs Up
Post #689315 29th Mar 2024 12:40pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
I've just done 6000 miles with Castrol Magnatec 5W40 C-3 in an SDV8.
This was prompted by the fact I knew I was going to be hammering the motorway miles and I had considered the LR-Time videos on oil for the V6.
Noticed no difference in economy or any other observable metric, but having pulled out a half litre for sampling purposes it is much closer to new 5W30 in viscosity at 6k miles.
The oil anlysis came back with a clean bill of health as well, very little diesel in it too.
Interesting experiment which if I had a V6 I would be persisting with, but as the V8 doesn't have the same issues I will be using 5W30 to the Ford spec going forwards.
I always change engine oil at 6-8k.
Post #689319 29th Mar 2024 1:16pm
Gremlin500
I downloaded the C1 and C4 specifications documents directly from the ACEA website, and went through the 3 pages of specs line-by-line. It’s remarkable how little difference there is between them, most of the parameters are identical, with only a few very minor differences, and C4 is classed as “Low SAPS” therefore will not damage your DPF. I don’t give a sh*t that it doesn’t meet JLR spec, the JLR crappy spec oil is a higher risk IMHO, chosen for fuel economy and not mechanical longevity. 5W40 C4 is a more prudent choice than 5W30 C1 if you aren’t hamstrung by a JLR Warranty.
“Tested by JLR” Yes, to work out if it would meet economy targets and just squeak them through the Warranty period, probably. Twisted Evil V6 Vogue - “Less is More” - less to go wrong!
Post #689327 29th Mar 2024 3:59pm
toby1
Thanks for the info S.L.
I am due an oil change now (it's on 156,000-ish miles) and I will use 5W30 as per the manual.
Post #689329 29th Mar 2024 4:07pm
D3Jon
But isn't C3 mid-SAPS, so bad for blocking your DPF?
EDIT --> Or is mid SAPs acceptable as well?
J 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #689337 29th Mar 2024 5:01pm
Gremlin500
Don’t use C2 or C3 on a DPF car! It’s fine on older L322’s etc without DPF of course.
This is an L405 thread folks, so L322 stuff isn’t relevant, and may confuse people. Shocked V6 Vogue - “Less is More” - less to go wrong!
Post #689343 29th Mar 2024 5:34pm
Stick Legs
The Castrol Edge 5W40 C-3 meets Ford WSS-M2C917-A
The manual recommends it meets Ford WSS-M2C924-B (which corresponds to 5W30 A-5)
The Castrol Edge 5W40 C-3 has a SAPS content of <0.8%
The recommended oil has a SAPS content of <1.2%
so actually lower in Ash content than the reccomended.
IANAE but if the oil is meeting the viscosity score across the operational temperature range, if the SAPS figure is within the range that is specified then there is little to be concerned about.
Not compliant doesn't always mean substandard, I also know that manufacturers do run thin oils to get past certain hurdles in regulation, so my choice to run the 5W40 C-3 was based on a lot of hot high speed running which I thought a thicker oil on an older engine would benefit from.
Now I have dug further into data sheets I am inclined to stick with the 5W40 C-3, especially as the oil sample testing backs it up.
I am not recommending anyone does what I say, just sharing my experience.
Post #689345 29th Mar 2024 5:53pm
Gremlin500
@Stick Legs:
Both C2 and C3 are classed as “Mid-SAPS” so will clog your DPF faster than C1 or C4 which are both “Low SAPS”, so why would you , when you can get 5W40 C4, and have the best of both worlds?
I would never put mid SAPS oils in my L405, no way. V6 Vogue - “Less is More” - less to go wrong!
Post #689360 29th Mar 2024 7:43pm
Stick Legs
Oh I agree, and having seen that will use C-4.
The only point I was making was that the Land Rover spec WSS-M2C924-B is an A-5 oil, which C-3 exceeds.
Post #689363 29th Mar 2024 7:51pm
D3Jon
This might be me, but I thought the point of your thread was that you can't easily get it (right now), unless buying $20K's worth direct from the Emirates? <<confused>> - Where's the confused emote on this forum? Very Happy Very Happy 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #689367 29th Mar 2024 8:24pm
Gremlin500
@D3Jon:
No, the point of my thread was that I’d found the “Holy Grail”, -a 5W40 C4 that would directly replace the watery C1, yet not f*ck up my DPF, knowing that a C1 5W40 simply doesn’t exist.
The other point of the thread was to gauge interest, before I decide how much of it to buy, assuming the price isn’t silly.
It does seem this whole subject is poorly understood in general, and also that folks are scared to try anything that hasn’t passed through JLR’s approvals process.
What will those people do when C1 becomes unobtanium in a few years? Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #689373 29th Mar 2024 9:23pm
D3Jon
Gotcha Thumbs Up Hope you can bring some across, reckon you should have plenty of interest!
2014 Disco 4 HSE
Post #689380 29th Mar 2024 10:33pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
If there was sufficient interest would a company such as Smith & Allan or Westway not be interested in blending an oil that is 5W40 C4 spec for us? Must be easier than importing from the UAE if so.
I think there may be a growing number of TDV6 owners wishing to move over to such a ‘new spec’ especially as the engines reach higher mileages.
They could produce it under the ‘LR Time Dumb Ass’ label/brand. And I think Christian and Vera should receive royalties from each sale.
Post #689385 30th Mar 2024 1:28am
Reading through this thread, can I assume this is fine for my MY17 4.4 then - https://www.smithandallan.com/product/smit...e-oil-4127 Got - 2017 SDV8 Autobiography in Loire Blue
Post #689388 30th Mar 2024 7:57am
caymanblack
Yes ,but Gremlin is suggesting 5w-40C4 might actually be better. overfinch modified
Post #689404 30th Mar 2024 11:58am
