![]() | Home > Technical (L322) > " RED" Restrictive Performance |
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246
where are you located? I did mine with IID tool 3 years ago with a similar reading. I had had RPs on the M4 and yellows but once it just popped straight to red. It was my pax inlet manifold so if yours is original (they strengthened the newer ones) then it may pay to have a HIGH pressure smoke test. can't remember the exact procedure but it required resetting the DPF values IIRC. if close I may be able to pop by and help? |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308
Forced regeneration just requires the latest software which you can download yourself from your account page. Check for intake leaks and do a full fault check but Do not reset the DPF. 2012 TDV8 Vogue (L322) |
| Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200
Hi Dolphinboy and thanks for your reply. I’m near Cheddar and 1 mile out from it. I have emailed Gap in Canada but it’s Easter and think I will need a program update from them. From memory they need a forced regeneration with the iigap tool unless it’s already there and I didn’t find it. I’ll have a look under the bonnet for a clue but I am no diy engine guy.
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486
I think you should be investigating why you've got a red in the first place.
Thanks JayGee
Latest software has the forced regen feature but as Gary says you need to thoroughly investigate the cause as a red warning is an indication of a fault and not operator error although I would suggest for future reference that a 20min run at 40mph is way too short a time and slow to allow the car to fully clear the DPF. 2012 TDV8 Vogue (L322) |
Thanks to Garry also
A short burst indicates a definite boost leak that needs to be found and resolved. 2015 Range Rover Autobiography 4.4 SDV8 |
garyRR
A puff of smoke when the revs go past 2500rpm is normal and nothing to do with the DPF. A forced regen is done while driving and not on the drive so no need to worry about the neighbours. You will need to allow for a good long drive pref on a dual carriageway or motorway. 2012 TDV8 Vogue (L322) |
Just to be clear - is the restrictive performance a red DPF warning symbol?A fault with the 2nd turbo crossover valve can also trigger a general restricted perf warning when going over 2500rpm. 2012 TDV8 Vogue (L322) |
Hi JayGee
| Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 76
Your symptoms sound exactly the same as I had when I first purchased my l322. My vehicle has never had the turbo drain mod, and I think the previous owner had never exceeded 2000 rpm. The result being when I first gave it the beans, there was a massive smoke screen, and I think the DPF became contaminated with unburnt engine oil. This resulted in a red restricted performance triangle, which required a forced regen to sort it. |
Thanks Dtech for your response and i am now looking at a forced regeneration using the IID gap tool procedure when confident to try it. Obviously I need to keep doing a decent run more frequently.
