![]() | Home > Technical (L322) > replacing the passenger seat |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 817 ![]() ![]() ![]() |
O, so every one thinks the same as me RR 2005 4.4 petrol
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
i dont think there will be a problem with the change over but i'd double check the connections on the sensor before changing the seat. ... - .- -.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Did you check if there is a fault code logged for the old sensor and did you clear it ? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
As Dutchgit says, the airbag fault is a hard fault that means even when fixed you have to reset it with diagnostics... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
If you change the seat, you will need to find a seat that's of a similar age, as the wiring/can-lin maybe different? And you have to avoid the 07 facelift seat change... |
strange, i changed the occupancy sensor on my old 2005 td6 and didnt have to reset the warning light on the dash.. ... - .- -.
Weird Stan, when I removed the seat in my 2002 it threw the light which wouldn't cancel until I cleared it with the IID... Pete
indeed Pete..
i had an airbag problem and didnt use the car for some time
