Home > Technical (L322) > replacing the passenger seat
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
hi, i have a warning for the seat occupancy sensor, i changed the censor but that did not fix it, i think the fault is in the seat.
if i replace the whole seat, will i need to have it reset, or can i just change it
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #689039 26th Mar 2024 2:38pm
knares
O, so every one thinks the same as me RR 2005 4.4 petrol
Post #689531 31st Mar 2024 5:38pm
i dont think there will be a problem with the change over but i'd double check the connections on the sensor before changing the seat. ... - .- -.
Post #689559 1st Apr 2024 9:42am
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Re: replacing the passenger seat
Did you check if there is a fault code logged for the old sensor and did you clear it ?
Post #689560 1st Apr 2024 9:50am
As Dutchgit says, the airbag fault is a hard fault that means even when fixed you have to reset it with diagnostics... Thumbs Up Pete
-Click here for Thread-
Post #689567 1st Apr 2024 11:44am
If you change the seat, you will need to find a seat that's of a similar age, as the wiring/can-lin maybe different? And you have to avoid the 07 facelift seat change... Thumbs Up
Post #689569 1st Apr 2024 12:06pm
strange, i changed the occupancy sensor on my old 2005 td6 and didnt have to reset the warning light on the dash.. ... - .- -.
Post #689570 1st Apr 2024 12:06pm
Weird Stan, when I removed the seat in my 2002 it threw the light which wouldn't cancel until I cleared it with the IID... Pete
Post #689580 1st Apr 2024 1:35pm
indeed Pete..
i didnt have the iidtool then so i'm certain that the light went off with the replaced sensor. ... - .- -.
Post #689584 1st Apr 2024 2:04pm
knares
i had an airbag problem and didnt use the car for some time
when i started using it again, the light was off
as soon as some one sat in the seat, it came on and is on permanently now RR 2005 4.4 petrol
Post #690281 9th Apr 2024 4:48am
