Home > Technical (L322) > *EDIT* Climate seats retrofit to Vogue [Fully Working now].
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
I've done the ol' 'replaced my heated seats with the climate seats' upgrade as I've always liked the cream interiors and when the opportunity of getting an ivony interior from an AB arose, I just couldn't resist. The seats are so much comfier than my old ones and just look lovely in my opinion.
Anyway, I've replaced everything except the seat loom inc the control panel and control module. Talking to breakers has been more miss than hit in trying to get this loom that's needed. Would anyone here have access to a parts catalogue (SDD?) to obtain the required part no for the loom?
This would help I think in sourcing a loom, even if it meant going to JLR... Shocked
While I can live without the heated/cooling function, the missus keeps berating me when it's a little 'fresh' outside... Cam
2011 TDV8 Vogue in Stornoway Grey
Post #689587 1st Apr 2024 2:12pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
should be able to track it down from here as this will give you the part numbers (and a small heat attack at the prices!)
https://parts.jaguarlandroverclassic.com/c...ver-parts/ 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #689648 1st Apr 2024 8:48pm
telly-addict
Cheers Paul. Heart attack indeed! Those are some quality parts prices lol. However, I kinda got lost looking for the loom I'm after...it looks like it may be LR022910 or LR022911/ LR030943 or LR030944, but they're the whole loom! Didn't think I'd need the whole thing...still, if I do it might help with breakers etc so the search continues...
Thanks again. Cam
Post #689781 2nd Apr 2024 9:47pm
telly-addict
Update on this - I finally managed to get a loom to do this (all 35 kgs of it!) and booked some time off to do the job. Stripped out the interior and centre console to be able to lift the carpet, only to find the missing connectors tucked away... Rolling Eyes
Anyway. Rebuilt everything, fitted new seat climate module and plugged everything in. Coded the new module, seats and HVAC control panel in SDD. Seats are now 'installed' and the seat module too along with some updated firmware. Unfortunately the HVAC panel doesn't want to turn the seats on. Checking through diagnostics, the HVAC panel all seems to work apart from the seat controls...all buttons and controls work for everything else, but monitoring the seat buttons when pressing...nothing.
The HVAC still has a permanent DLC for wrong configuration, despite being coded for the vin and updated with new firmware. I'm wondering it it's the wrong part no (sourced from ebay)...maybe from a newer model (seats are from 2007 I think). Cam
Post #694278 11th Jun 2024 11:06pm
mgrover
feels like your missing a setting in the ccf.
also do you mind explaining what you need in terms of hardware to make it work?
am a bit confused on the loom part. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #694309 12th Jun 2024 12:31pm
telly-addict
You could be right, I may have missed something.
In terms of hardware, I thought I had everything but was suspecting I had the wrong climate control panel/module. Cam
Post #694406 13th Jun 2024 11:36pm
mgrover
can you see the panel buttons in gap live values?? and if they do anything?
the 2007 seats maybe the problem but what do I know. Its actually a sport Sad
Post #694425 14th Jun 2024 11:45am
telly-addict
I was watching them through diagnostics yes, all the buttons responded except the seat ones - nothing in the live values. Cam
Post #694458 14th Jun 2024 10:05pm
mgrover
defo then feels like you are missing some ccf config.
i had a similar issue when I was doing adaptive cruise control and was missing some odd obscure setting.
maybe someone with the seats can do a dump of their ccf config. Its actually a sport Sad
Post #694473 15th Jun 2024 10:32am
telly-addict
Hmm it does seem that way. I'll try and hook it up today and have a look Thumbs Up Cam
Post #694483 15th Jun 2024 12:31pm
telly-addict
You were on the money. Checked over the settings and found one [Heated Seats| Heated Seats] that initially looked like it was correct, changed to [Heated Seats|Heated & Cooled Seats] Rolling Eyes
Now it all works. Very chuffed I got this working. Thanks for the input Thumbs Up Cam
Post #694522 16th Jun 2024 2:53am
mgrover
Ah thata great
Do you mind listing exactly what you needed to make it for from a stock car?
Am guessing you didn't need an entire car loom in the end and maybe where we can find the connectors? Its actually a sport Sad
Post #694524 16th Jun 2024 8:12am
telly-addict
I got the entire interior from an Autobiography from the glovebox down, front to back.
As far as the climate seats are concerned, along with them (and for me only the fronts were climate, if rears were climate there would be additional settings in ccf) I replaced the HVAC control panel and added the Drivers Seat Climate Control Module - the plastic tray under the driver's seat is designed for the DSCCM to clip into it, so there's no doubting where it should go. When I had everything stripped out the car to lift the carpet and compare wiring looms, I was scratching my head when trying to marry up the connections...I couldn't see a difference. It was only when I offered up the DSCCM to the connections in the car that I realised that they must have been hiding under the carpet and I didn't notice when pulling it all apart. They definitely weren't there before. I suspect it may be the same for anyone else with normal heated seats. At least from 2010 onwards, perhaps earlier. What's slightly interesting is that the rear seats, although just heated like the old ones, don't have any pressure sensors for telling if a passenger is sitting on them. So they have one less connector. I can only assume that from 2010 onward it was a statutory requirement. I actually liked this as I didn't have to say anything to rear passengers, the car nagged them instead Laughing
So to summarise, to upgrade to climate seats you will need;
    * Climate seats shocker
    * HVAC Control Panel from car with climate seats
    * Drivers Seat Climate Control Module
    * Modified CCF to allow it all to work
Hopefully that will help someone. Smile Cam
Post #694554 16th Jun 2024 4:25pm
