![]() | Home > Maintenance & Mods (L405) > Does it just pull off. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
I've searched and looked in the Wiki but I can't find the answer. I wanted to look and see If I had a secondary battery or a capacitor but unfortunately failed at the first hurdle. I know where it lives but I can't seem to remove the trim panel (offside in boot) does it just pull off. I used a bit of force but it didn't budge, unfortunately I have a habit of breaking things so as I'm sure someone has already done it (removed the panel that is without breaking anything) I just thought I'd better check for any tips or if there's a knack before just resorting to more brute force. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I start in the middle at the top and get my fingers in and pull down and out that's where other fuses are located. 2017 SDV8 4.4 silicon silver AB
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
done this many times when i was researching the stop/start situation.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
It's slotted in at the bottom, so you have to pull the top out like this -
