Home > Technical (L405) > Restricted performance, Engine won't turn off...
I was darn sooth for a couple of days, been driving for 10miles on minor "A" roads when "restricted performance" came up on the dash, no bong at all but there was no power, was coming to a slight incline so managed to pull off the road.
Went to turn it off, pressed the button and the engine started to die but instantly the ignition came back on quick enough to keep the engine running so basically I couldn't turn it off, I tried about 10 times and the same thing happened, switch off then back on before the revs dropped.....
Weird thinks I (I'm quick like that) I then thought what happens if I press and hold the on/off button? this worked and the engine switched off and the gear knob disappeared... then.... "bong" "Not in Park" came up on the dash, did about 3-4 bongs then disappeared then did it again, just kept cycling between blank dash and "Not in Park" obviously no way to put it in park and it now wouldn't turn back on... nothing on the button...
I reach for the big guns, out comes the IID and a short time later it's reading faults.... Just one
HVAC-Ventilation
B13C2-49 (6C) Windshield misting sensor - System internal failure - internal electronic failure
An old fault which one day I will replace...
I cleared the faults anyway and the IID shoved up lots of failure messages but was cycling through the ECU's
Then the bonging and the Not in Park messaged disappeared, I hit the start button, it started fine, with restricted performance now gone, drove on fine...
Drove around Londinium for another day, then 200 miles home, been out in it several times since and it's behaving impeccably.
I wondered about voltage but the main battery is brand new, just a week old and the second battery is at 12.6v at rest so I don't think voltage had anything to do with it...
Anyone come across this, is it a precursor to imminent failure, will it live till Christmas, should I sell it... Answers on a postcard Laughing
Pretty picture because we all like a photo...!!
 Pete
Post #694194 10th Jun 2024 12:35pm
new battery , maybe loose connection? ... - .- -.
Post #694198 10th Jun 2024 12:49pm
Checked and double checked Stan, I instantly thought voltage but both batteries are perfect and correctly fitted...
It's probably one of those fatty idiosyncrasies.... Rolling Eyes Pete
Post #694201 10th Jun 2024 1:28pm
you're probably right Pete but its frustrating not knowing the cause..
only other things i can think of is the earth strap [under wheel arch?] and the stop/start switch.
i reckon you'll wake up at 3 am and know what it is... Very Happy ... - .- -.
Post #694203 10th Jun 2024 1:45pm
Thanks Stan,
I did the earth straps when I did the ACE pipes so they are all good....
Stop/start button was changed when I bought it and I don't think that would chuck up the restricted performance, might do the turn off issue but it is just a switch that connects two wires so I doubt it...
It seemed a very specific issue so just wondered if anyone else had succumbed to it.... Pete
Post #694208 10th Jun 2024 2:06pm
fisha
It almost reads like there wasn’t enough power to go round, and that you were getting brown-outs of the systems in their electrical supply. ( like when you say the engine started to die, but the dash came back up as there was power now available the engine wasn’t using it)
Wonder if something like one of the main power relays were switching and so you were losing power partially. But on further startups they were holding ? V8 or else ...
Post #694263 11th Jun 2024 5:16pm
Thanks for the thoughts, you could be right, I put it on here to see if someone had had similar but it appears not. I don't think I'm going to be able to search for it unless it does it again and stays like it..!!
If something is dying I suppose I will be the first to find out... Rolling Eyes
If not it's because it says "Range Rover" on the front and back Whistle Laughing Pete
Post #694266 11th Jun 2024 6:16pm
Here we are, 4 months and several thousand miles of fault free motoring and it does something similar...
Driving to Manchester airport to pick up daughter, 200 mile round trip, rush hour so lots of speed restrictions so the ACC is working overtime, about 80 miles from home and "restricted performance" comes up on the dash, we are doing around 60 and the car seems to run fine, as the traffic clears I accelerate to see if there is power and nothing happens, the cruise is holding it to 60, but set for 70, not enough performance to go any faster...
We were running late as there had been an accident so didn't have much time but stopped at the next services and switched off, all dash lights went out as usual but the engine was still running, no ignition on, a black dash but engine still running, it ran for about 5-10seconds (seemed like an hour!!) then switched off.....
Left it a few mins and restarted which it did fine but still with "restricted performance " showing. I pulled away and you could feel it was sluggish, I'd stopped in the petrol station so nowhere else to go but back out onto the motorway (with hindsight I'd have stopped in the car park)
It drove like a flat pancake but I soon realised the cruise was the best thing to use, set it, then increase the set speed and the engine would slowly get to about 60 with no problem.
We picked daughter up and I left it running, we drove a few miles to a pub for dinner, switched off and yet again the engine stayed on, then after about the same time, switched off...
We went inside and ordered and as we were waiting I went back outside and it started fine, with no faults showing....
I plugged in the IID, and it showed no fault codes apart from...
Using IIDTool BT V4.0 B2803
ACM-Audio System
B119F-11 (2C) GPS antenna - General electrical failure - circuit short to ground
HVAC-Ventilation
B13C2-49 (2F) Windshield misting sensor - System internal failure - internal electronic failure
( on 07-06-2024 15:46:05 at 78224 mi )
TVM-Television
B1D56-11 (2Cool Antenna 3 circuit - General electrical failure - circuit short to ground
These all cleared and only the misting sensor returned which has been there since I bought it
I switched it off, turned off immediately, had dinner, started fine again and drove 99 miles home with no issues...
This morning I have checked the batteries connections, and have looked at, prodded and poked anything else I can think of... IID still only showing the misting sensor...
Weird as well that there is no "bong of doom" at any time....
Sorry for the waffling but it is a weird fault and I was wondered if anyone else had had something similar...?
Picture as we all like one and you have been good reading this far... Thumbs Up
 Pete
Post #702443 18th Oct 2024 10:15am
could be,
split inlet manifold or hoses
map/maf sensor
egr valve ... - .- -.
Post #702456 18th Oct 2024 11:11am
Thanks Stan, I was thinking something similar, I gave it a full throttle test on the way home and it was fine so I don't think it's a split or a leak.... (you forget how rapid these things are when given the beans!!)
There is no misting anywhere under the engine cover...!!
Maybe I'll clean the map/maf and egr but I would have thought it would have chucked a code up for them..??
Sort of wish it would just break....lol....
(has anyone ever said that before....!!!) Pete
Post #702457 18th Oct 2024 11:25am
fisha
I think you need to have that IIDtool with you all the time and read the codes as soon as the error pops up.
Is the foam thingie in the bonnet loose like the LR TIME youtube video?
Is there oil in the intake around the throttle body ?
When did you last change the air filters ? My BMW 640d threw a sporadic engine light error recently, which on investigation turned out to the air filters and there being a bad batch / poor design which was restricting the airflow into the engine enough it could sense it and throw an error. Changing to a new air filter has made a marked difference to the car.
If the car is sensing it cant draw enough air, could it be going into restricted modes ? Could it be trying to draw air from the system such that its pulling oils past seals which is allowing the engine to run-on ?
( I dont know btw, but my gut is telling me its in the inlet system somewhere ) V8 or else ...
Post #702501 18th Oct 2024 7:02pm
Thanks for the input and taking the time to type all that, the IID lives in the car and was used immediately, any fault code will stay on the list until it's cleared...
Foam in the bag under the bonnet is fine, filters are genuine and only a year old and very clean...
No undue oil anywhere, I did take the pipe off this morning...
The running on was specific as if power had not been switched off....
Restricted performance came up at about 60mph on cruise gave no audible beep and put on a red engine light but still no codes....
It now runs beautifully, no faults, no smoke, no hiccups, oil level is fine, mpg is as it should be....
I'm wondering if it was as a result of a DPF regen, I'll have a look at those values tomorrow Thumbs Up Pete
Post #702506 18th Oct 2024 8:17pm
fisha
Could it be a split which opens only on negative plenum pressure rather than under boost?
Such as overrun whilst cruising along, or when you switch it off, in both cases throttle body closes and it starts drawing through the split ? V8 or else ...
Post #702516 18th Oct 2024 9:00pm
Thanks again, I've just been chatting with a mate who used to work for JLR as an engineer.
He's never heard of it before but is leaning towards an engine / transmission ground strap that has high resistance, or a poor connection, not along the lines of the wheel arch ground points but high enough to cause a difference between the chassis ground & the engine ground.
The lack of DTC’s suggests that it’s not a component or communication error, nor a ‘leak’ on the induction or charge air side – the ‘transmission not in park’ is the one that is saying low operating voltage due to the poor ground to the engine / transmission.
It won't be used now till February so I'll book some ramp time and have a good look... Thumbs Up Pete
Post #702529 18th Oct 2024 9:59pm
Well here we are 7 months later and it does it again
Red restricted performance and small red triangle illuminate on dash but NO bong of doom.
Was doing 70mph on cruise, dropped to 60mph and no power.
Pull off the motorway and stop.
IID was already plugged in so used before anything else... No faults at all showing
Tried to turn off, dash closed down as usual but engine still running just like it wasn't turned off, press and hold Stop switch, 6 seconds (yes I timed it) later the engine turns off
Left it a minute or so and it restarted as it should but straight away restricted performance came back, no power so stopped again, it did the same as above three further times, I was only a few miles form home then so took it slowly and got home...
IID still no faults...
Press and hold stop button, dash powers down immediately but engine stay on for 6 seconds....
I have two Bluetooth battery monitors and both show good voltage and SOH out of both batteries...
I had checked, stripped, cleaned and redone all the ground points and anything else I could find since the last time it did this 7 months ago...
Another chat with JLR master tech comes back with
I’d say it’ll likely be a corroded connection on an EGT sensor giving an implausible (but not excessively so) temperature reading, hence no DTC. The most likely one is the b’stard just after the exhaust branch, effectively under the drivers seat, I’d be checking the connector for corrosion and fretting. LR specify NyoGel 760G for filling the contact housings with, works a treat on EGT sensors and SRS connectors where there is low current but resistance sensitive connections being made… you could also check the live values of the various EGT sensors and look for one that is out of range of the others, being left to cool down suggests there’s an errant reading somewhere.
I've ordered some Nyogel 760G and will be following his suggestions...
Just thought I'd update this in case it happens to someone else..
If anyone has any other ideas or thoughts please chip in...
Thanks for reading...
Just a random thought but maybe fatty doesn't like it's new grille, I know I don't.... Whistle Laughing
 Pete
Post #717428 5th May 2025 10:05am
