![]() | Home > Technical (L322) > Low Battery - Start Engine warning. Definitive Answer? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 377 ![]() ![]() ![]() |
Battery on 4.4 tdv8 should be AGM. I would check voltage …approx 14.4 with engine running and charging, around 12.6 switched off.
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 371 ![]() ![]() ![]() |
My L405 did the same when we bought it and drove me nuts. However, after regularly running the car for a few months, the message no longer pops up. I would use it for a few months and see what happens. |
TDV8Graeme Member Since: 24 Jun 2024 Location: Cumbria Posts: 12 ![]() ![]() ![]() |
As it isn't causing me any probs atm - that's worth a try!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Definitely needs an 019 AGM fitted tbh Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Right..............
Common knowledge they are self healing cars. Seen it dozens of times |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3845 ![]() ![]() ![]() |
If it is any comfort mine has regularly done it from new.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7950 ![]() ![]() ![]() |
I’m sure that dealers had a fix, back in the day…. Of a software update as the system was too eager to shout Low Battery. I’m guessing most will have had that update by now. I have no further details.
