Home > Technical (L322) > Low Battery - Start Engine warning. Definitive Answer?
TDV8Graeme
Hello!
Right, new to all this RR lark - so be gentle.
2011 TDV8. I've got the "Low Battery Start Engine" warning, which I understand from rummaging around this and other forums is not uncommon. What I can't find is a definitive answer as to what is wrong!
I thought when I bought the car - "OK, it's been standing a while at the dealers, a good run will sort this out". But 178 mile drive home and the message is still there.
There is no problem starting - it is instantly on the button - and everything works absolutely fine. Certainly there are absolutely no symptoms of a flat or dying battery.
I THINK the battery is fairly new, although there is no receipt for it in the file which is odd, but the clock and date were wrong when I bought it which indicates to me that the battery has been disconnected recently, (?), perhaps to fit a new one?
So is it:
1) Actually a knackered battery - despite there being no other symptoms.
2) A charging problem
3) The "Wrong" new battery fitted? Pic of battery fitted attached if that helps.
4) That the battery hasn't been "coded" to the car when fitted??
Help! It really isn't causing me a problem - I start the car when I get in anyway - but I'd like to get is sorted out.
TIA
Graeme
Post #695132 27th Jun 2024 10:45am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Battery on 4.4 tdv8 should be AGM. I would check voltage …approx 14.4 with engine running and charging, around 12.6 switched off.
Next thing to check is that the battery connections are tight. The fact that it is starting ok would suggest that there is no major issue. RR are very susceptible to low battery performance. You will get the message if you watch the TV or listen to the radio for any length of time without the engine running.
If you are leaving the doors open for any length of time I would knock off the internal lights by holding in the light switch by the rear view mirror.
If it wasn’t starting well the issue could be the earth cable on the passenger side wing behind the wheel arch plastics. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #695133 27th Jun 2024 11:27am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
My L405 did the same when we bought it and drove me nuts. However, after regularly running the car for a few months, the message no longer pops up. I would use it for a few months and see what happens.
Post #695134 27th Jun 2024 11:42am
TDV8Graeme
As it isn't causing me any probs atm - that's worth a try!
Thank you.
Post #695135 27th Jun 2024 11:45am
DrRob
Definitely needs an 019 AGM fitted tbh Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #695137 27th Jun 2024 12:00pm
TDV8Graeme
Right..............
Clearly my car was so embarrassed that I've shown it up by asking a question on here..... it has decided to fix itself!!
Message gone. And no current error messages displayed!!
Ohh how I shall enjoy the foibles of RR motoring!!! Rolling with laughter Rolling with laughter
THANK YOU though, everyone for your inputs Thumbs Up Thumbs Up
Graeme
Post #695142 27th Jun 2024 12:34pm
DrRob
Common knowledge they are self healing cars. Seen it dozens of times Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #695145 27th Jun 2024 1:31pm
Baltic Blue
If it is any comfort mine has regularly done it from new.
I know the original battery was upgraded to an 019 AGM on a factory recall and I replaced it at 5 years old but decided against recoding the car at the time because other trusted forum friends were experiencing under charging problems when they had recoded.
Now8 years later it still appears if I sit listening to the radio etc without the engine running.
I know the time for me to change the battery again is well overdue but it’s still working fine.
Post #695146 27th Jun 2024 1:33pm
mjdronfield
I’m sure that dealers had a fix, back in the day…. Of a software update as the system was too eager to shout Low Battery. I’m guessing most will have had that update by now. I have no further details.
Mine does it every so often.
Gone are the days of having the radio on whilst you wash it…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #695148 27th Jun 2024 2:38pm
