![]() | Home > Technical (L322) > L322 4.4TDV8 Westminster Top End Oil Leak |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3325 ![]() ![]() ![]() |
The brake cleaner will just wash the oil off and it will drip down under the car so just make provision for that. No need to wash it off as it will evpourate so don't do it in an enclosed space. Never liked steam cleaning in engine bays as the water gets into the electical connectors. 2012 TDV8 Vogue (L322) |
kernokerno Member Since: 12 May 2024 Location: cornwall Posts: 12 ![]() ![]() |
Thanks for your help JayGee will update how i get on |
Ok just an update
Ok managed to find part
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 377 ![]() ![]() ![]() |
I would do an oil/filter change anyway. I used a pump and it appeared to get most of the oil out.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 690 ![]() ![]() ![]() |
Hi, Oil floats on water so assuming the extraction tube goes to the very bottom of the sump it should pull the water out before the oil so you may be safe.
The extraction tube connects to the sump drain plug so it gets as much out as if it had a sump plug. 2012 TDV8 Vogue (L322) |
