![]() | Home > Technical (L405) > oil level not available |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3833 ![]() ![]() ![]() |
Try opening the bonnet, engine off, then double click on the cruise control cancel button.
Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 12 ![]() ![]() ![]() |
Thanks for the swift reply, I have tried that but it didn't work, I couldn't find any reference to the sequence working on post 2018 facelift cars, should it? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1364 ![]() ![]() |
Mine is Facelift 2018 and this works.
Thanks, but mine is a 2020 v6, there are no outstanding campaigns, the oil level sender and wiring are different to your v8, and this maybe why the sequence you suggest doesn't work. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1739 ![]() ![]() ![]() |
@Monty:
I will have a look when it stops raining, thanks.[/u] |
Its finally stopped raining long enough for me to get under the car and remove the undertray and the issue is I believe resolved:
Hi Monty,
Hi Monty, see this thread (sorry!):-
:oops: Not sure if the TDV6 has the same sensor issue, can someone advise? |
Hi No I don't think it does, I believe it is a different sensor and loom. |
Hi Monty, sorry if that was a red herring, but checking online gets confusing results, and the WM on here isn’t easily searchable and seems to be V8-oriented.
Spleen Member Since: 11 Feb 2022 Location: Wilts Posts: 93 ![]() ![]() ![]() |
Here’s a weird one, just changed the oil on my wife’s 2016 3.0 RRS and reset the service interval (same procedure as the Fat) but it’s only reset to 4400 rather than the expected 16000+ miles. Appreciate it’s not an FFRR but does anyone have any idea why this might be? 2017 Vogue SE
