Home > Maintenance & Mods (L405) > L405 Transfer Box Oil Change & Judder Bulletin Double Fl
Page 3 of 4 <1234>
garyRR
No, I don't get any sounds like that. That does not sound a very happy transfer box.
Best way to describe mine is a bit more like axle tramp. Mine had been tentatively diagnosed as my active anti-roll bar in fact, pending diff and transfer box services (when I checked the history, they were last done at 60,000 and are due). 2015 Range Rover Autobiography 4.4 SDV8
Post #697167 30th Jul 2024 9:11pm
JoeDoyle
United Kingdom 2017 Range Rover Vogue SE SDV8 Silicon Silver
Did two transfer case oil changes, shudder lessened each time, will do a third change next week. Also did ZF filter and oil, front diff and electronic rear diff, hydraulic/power steering flush. Just purchased with 82k SDV8 the oil changes and adaption resets for each make a massive difference.
Post #698273 17th Aug 2024 11:01pm
PLOG
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Has anyone managed to fix this long-term yet?
2019 5.0SC with circa 42k miles...
Asked the specialist to do the double flush and update in the hope it would solve the slight judder I felt from the rear when pulling away and turning slightly left. They did, and it didn't. (£300)
They then said there's 'play' in my prop shaft and changed that. That didn't make any difference. (£1500)
Then they said it needs a new transfer case, which it's now had. (£6500)
The issue remains and I've no idea where to go from here. I've lost faith in the specialist I'd been using for years as they just seem to guess and throw parts at it. Luckily most have been covered by my warranty, but I've still had to part with around £3k to be no further forward! They're also so busy that they don't really seem that interested in trying to solve it anymore and there's a wait of several months to book it back in anyway.
I'm even considering the main dealer now, but is there something that could have been missed here or another part I should be looking at? I was hoping a spanking new TC would've fixed it, but it only improved it slightly...
Post #699030 29th Aug 2024 3:27am
knwatkins
If a new transfer case hasn't solved it and the TCCM has definitely been updated, it is a possibility that you have a different problem to that of the transfer case judder in this thread. The transfer case judder I was experiencing was quite violent, not slight.
Have your diffs been ruled out? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #699031 29th Aug 2024 6:07am
PLOG
I did a lot of reading about it beforehand and the LR Bulletin was exactly what I was experiencing (and still am), so I was convinced the double flush would work.
"A customer may express a concern that a judder is felt from underneath the vehicle when using steering input at low speeds, for example turning left or right at a junction" - exactly my issue.
I did ask them "could it be the diff?" several times and they always said no. Would that make the same kind of judder? I'd read that failing diffs whine is all.
The only other thing I can think of is that they maybe haven't updated the TCCM / software correctly, or at all. They said they have, but I've lost all faith having been told by the advisor that they'd done things when they hadn't before.
Post #699093 30th Aug 2024 3:14am
PLOG
knwatkins - Where did the judder / noise feel like it was coming from for you? It feels like it's coming from the rear left on mine.
Post #699094 30th Aug 2024 3:18am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Same problem here, after two years of complaining about the clonk, they replaced the rear diff under warranty.
Which did not fix the problem.
Someone thought to look at the bulletin from JLR.
They did the double flush on the transfer case, which solved the problem.
However, I tried to claim this from the warranty but was told it had not been done when I had an Indie do the service Censored so as I did not pay then, I would have to pay now.
This work should be done at 5 years or 80000 miles, my car has only covered 25000 miles in 7 years
The cost for the flush is £255 44 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #699097 30th Aug 2024 8:17am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
is there a bulletin out for this issue ?................its ok i found it
Post #701500 4th Oct 2024 6:37pm
second post on page one. ... - .- -.
Post #701502 4th Oct 2024 7:10pm
will308f
Post #701503 4th Oct 2024 7:10pm
JoeDoyle
Did this and more
Did the flush, software update, didn’t work. Changed the transfer case and control module. Judder remained.
Got a temp lockup whilst driving, turned out to be abs sensor fault. Replaced sensor. Suspected abs grabbing.
Judder remained, changed motor on rear ediff, flushed oil twice, (clean oil) software update, judder remains.
Down the rabbit hole.
Next move is refurbish rear diff friction plates.
Having spoken to a few L405 owners with ediff It’s a common problem which most ignore. Aka get a better stereo. Very Happy
Post #702876 22nd Oct 2024 10:59pm
GraemeS
Australia
Did the ediff s/w update include recalibrating the ediff?
Post #702882 23rd Oct 2024 3:37am
JoeDoyle
Software update to control module, calibration through Gap tool self test. Changed the oil again yesterday, if anything it’s worse now, thinking of trying Dr Tranny
As for accuracy disconnect the wiring to the ediff motor, test drive, no judder. As mentioned new motor fitted.
Post #702906 23rd Oct 2024 12:14pm
GraemeS
Australia
I was surprised to learn that a relatively local to me LR specialist workshop rebuilds ediffs.
Post #702939 23rd Oct 2024 8:43pm
will308f
been having this problem ,just done first flush -software updated calibration carried out .......will be driving it around for couple of days then do the second flush and fingers crossed judder sorted
Post #703092 25th Oct 2024 10:43pm
Page 3 of 4 <1234>
