Home > Technical (L322) > Odd Instrument panel warning lights
STK79
Finland
Hello, i have 2002 td6.
Ignition key off, these warning lights will remain.
With motor running also these lights go on.
I had water ingress on passenger side (right side in finland).
Which ECU could cause this problem, i have run odb scanner, and no solution.
Sorry about my bad english, but i am from Finland 😅
Post #699630 6th Sep 2024 5:29pm
pcourtney
Welcome to the best L322 place on the internet Smile
Please test your battery, and the all the cables to the battery, you need clean tight connections and an excellent top quality battery, there are many faults/errors that seem to pop up when the battery on our L322's is not in top condition.
Post #699631 6th Sep 2024 6:17pm
STK79
Finland
Thanks for the advice, i will check that.
There is some water damage in LCM unit.
I removed lcm from car, and it's still the same situation. 2002 L322 td6
1973 Range Rover classic eternity project
2004 BMW 530d
1991 Fiat - Solifer 5500 camper van
Previous: 1997 P38 2.5tdse
and many others.
Post #699635 6th Sep 2024 7:09pm
pcourtney
well now you have the LCM out, have you cleaned the PCB, they get corroded and fail, so carefully clean it with PCB cleaner and a soft toothbrush, do you know that the backup Odometer is part of the LCM, so a new one would need to be programmed up for your car
Phoenix reminded me of this
and I quote "the LCM holds the backup odometer reading and VIN record, if not coded correctly or the data is at variance with the IPK, it'll force the manipulation point on the IPK. IIRC, the LCM is a 'suck, blow' configuration rather than just a 'code to vehicle'
Post #699637 6th Sep 2024 7:18pm
pcourtney
There is a guy in England who can repair your LCM if you cannot get it working
https://www.ebay.co.uk/itm/285161692657
Post #699638 6th Sep 2024 7:27pm
pcourtney
First Photo with ignition off
The green light is Cruise Control Active - Green
NB when the ignition is on - turn off the Cruise Control button on the left hand side of the steering wheel and see if it stays on when you switch the ignition off
Red light is just Seat Belt not plugged in, plug it in and see what happens, it should go out after 5 seconds
Above the Seat Belt sign is the EBA ( Emergency Brake Assist ) light, this could be a fault with the EBA system
Post #699695 7th Sep 2024 5:35pm
pcourtney
Second photo with ignition turned on
The red light far left is the Battery Charging light and should go out when you start the engine and start driving
The middle Amber light is DSC ( Dynamic Stability Control ) - this could be the DSC button is pressed on, so turn it off, it the light still stays on after driving for a few minutes a fault has been detected with the DSC, this is very common if the DSC has not been used for a few years
Above the green Cruise Control light is the Handbrake System Red Light, this comes on when the handbrake is applied - it should go out when you release the handbrake
NB All of this is in your Range Rover Owners Handbook Smile
Post #699697 7th Sep 2024 5:44pm
STK79
Finland
Thanks for answers.
I know what lights are, but they shouldn't be on cause everything works normally, i had sunroof leaked, and these lights came on, on lcm i have blinker problem, but these lights are mystery, which ecm controls these, i think there is water ingress. 2002 L322 td6
2004 BMW 530d
and many others.
Post #699702 7th Sep 2024 6:22pm
pcourtney
Have you cleaned inside the LCM yet, there is a PCB which often fails if it is not super clean
Post #699704 7th Sep 2024 6:42pm
STK79
Finland
I have cleaned pcb, havent tried on car yet, there was some corrosion on pcb. 2002 L322 td6
2004 BMW 530d
and many others.
Post #699712 7th Sep 2024 7:10pm
STK79
Finland
Lcm dried in oven, now it works.
But dash lights still not working correctly. 2002 L322 td6
2004 BMW 530d
and many others.
Post #700105 14th Sep 2024 10:16am
