![]() | Home > Technical (L322) > Odd Instrument panel warning lights |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1006 ![]() ![]() ![]() |
Welcome to the best L322 place on the internet |
STK79 Member Since: 14 Jul 2023 Location: Helsinki Posts: 5 ![]() ![]() |
Thanks for the advice, i will check that.
well now you have the LCM out, have you cleaned the PCB, they get corroded and fail, so carefully clean it with PCB cleaner and a soft toothbrush, do you know that the backup Odometer is part of the LCM, so a new one would need to be programmed up for your car
There is a guy in England who can repair your LCM if you cannot get it working
First Photo with ignition off
Second photo with ignition turned on
Thanks for answers.
Have you cleaned inside the LCM yet, there is a PCB which often fails if it is not super clean |
I have cleaned pcb, havent tried on car yet, there was some corrosion on pcb. 2002 L322 td6
Lcm dried in oven, now it works.
