Home > Technical (L405) > Intermittent Headlight
supershuttle
Well my problem is pretty much as it says in the title. The drivers side headlight is intermittent - why do I know? because today I was sat in the car with the lights on and the light just went off and on then stayed on.
Stan already suggested I check for a loose connection but I cant find one so anyone got any other ideas? Geoff
Post #699468 4th Sep 2024 2:45pm
further to my loose connection suggestion geoff, i think the bulb might be failing , possibly the filament breaking down..
only way to check is to replace bulb and see... ... - .- -.
Post #699484 4th Sep 2024 4:43pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Re: Intermittent Headlight
Possibly a failing earthing stud under the front wheel arch liner, when this fails it does affect the relevant headlight. If it fails completely then you'll certainly know as may systems go offline with accompanying warnings all over the dash. I'd go for the HID lamp first as Stan says and if it still occurs take a look at the earth point. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #699490 4th Sep 2024 5:08pm
supershuttle
OK I’ll get some bulbs ordered, D3S if my memory serves me. Any thoughts on which ones, I could do with a bit more brightness, these peepers of mine are getting old Rolling with laughter Geoff
Post #699498 4th Sep 2024 6:04pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
My money would be on earth stud about to go, any other strange happenings?
Post #699500 4th Sep 2024 6:19pm
supershuttle
Actually there is another fault appeared and its a parking sensor problem, apparently they are not working. Failed about the same time as the Headlight became intermittent so I will check the earth stud - when I find it!! Geoff
Post #699506 4th Sep 2024 7:50pm
4RRS
Whichever side headlight is playing up, remove the front section of the arch liner on the same side as the faulty headlight and check the earth mounting stud, there will be 4 earths to the stud (2 eyelets with 2 cables attached to each eyelet). Give it a bit of a tug and it'll probably fall off. I seem to recall that the ABS module is affected by the o/s earth and is one of the first things to flag a fault. Nearside is PDC sensors, headlight and low coolant/bonnet open faults.
Had this on the o/s on my L494, https://www.rrsport.co.uk/forum/topic59386.html which is the same wiring etc. lost speedo, ABS, gearbox and a whole load more items.
Have a look at https://www.fullfatrr.com/forum/topic62384.html
Prudent to check both sides as if one's about to fail the other wont be far behind. I got the official LR replacement earth post and used that, but you could use a rivnut or even the nearest mounting bolt (for the accelerometer) as an earthing point. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #699512 4th Sep 2024 9:35pm
supershuttle
Also a good time to buy LED headlights - as an experiment. Geoff
Post #699519 5th Sep 2024 7:22am
supershuttle
Any LED recommendations? Geoff
Post #699554 5th Sep 2024 2:10pm
supershuttle
Ordered some cheapo HID replacements just to test - only about 20 quid. Geoff
Post #699824 9th Sep 2024 12:48pm
Earth points....
Offside with four connections and a rusty bracket above...
[/quote]
Nearside with two connections, this looks fine but fell off when I touched it...!!
 Pete
-Click here for Thread-
Post #699826 9th Sep 2024 1:07pm
