![]() | Home > In Car Electronics (L322) > BCM/BCU unit replacement ..How-to.. |
| Billy'sLad Member Since: 02 Jul 2021 Location: Southport Posts: 8
Thank you for the excellent instructions and clear photos, it made my job so much easier today 👍 |
| bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455
It is very gratifying that my amateur efforts have been of help to others. That was what I had intended, so thank you for your kind comments.
| Midlifecrisis Member Since: 04 May 2021 Location: NI Posts: 7
I've got an intermittent problem with my 2002 3.0 diesel RR
| invisible999 Member Since: 13 Jan 2024 Location: Reno, NV Posts: 58
Thanks for detailed instructions, they were quite useful when I swapped my BCU today. I did not need to recode it.
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
after my last post, i still had problems.
So far I have not observed the same problems after BCU replaceme with rear doors/windows/tailgate - seems everything works. The only problem is that I can't lock remotely with keys - have use use physical key in door lock to lock/unlock it. Attempts to pair/re-pair key using the standard procedure did not help. |
| LASBAM Member Since: 04 Apr 2017 Location: Reutlingen Posts: 26
@invisible999 having the same issue as you have. Do you have a solution in the meantime? Current:
If you are asking about keys - I have not yet fixed yet. Locking/unlocking doors with physical key works fine. I recently got GAP ID Tool and it should have the capability to pair the key. Will look into this. |
i bought several ECUs off a guy who was wreaking his range rover, same year as mine
| All times are GMT |
