|  | Home > My Range Rover > 5 RRs and I have to give up |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | 3 old shocks and 1 new one would certainly make for a non optimal ride quality but at least the non CVD shocks are cheap and that should be an easy fix. Tyres and tyre pressure make a big difference on steering forces at low speed and IME OE pressures are a bit on the low side - what tyres and what pressures are you running?. I can palm mine if needed but it's not the lightest steering on a car I've had but then I don't like overly light steering anyway. 2012 TDV8 Vogue (L322) | ||
|  1st Oct 2024 8:42am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | my steering, when it decides to work, which is 95% of the time, is as light and positive as can be RR 2005 4.4 petrol
|  1st Oct 2024 9:36am |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | Agreed on the shocks,
|  1st Oct 2024 10:25am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | You don't think that the oversize tyres contribute to extra steering load? | ||
|  1st Oct 2024 11:34am |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | I'm aware they will have an effect Graeme but it was no different on the 255/50/20 it had when I got it. | ||
|  1st Oct 2024 11:40am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Just looking for possible reasons... | ||
|  1st Oct 2024 12:25pm |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3404      | Taller sidewall shouldn't impact the tread patch - wider tyres maybe. Try upping the pressures and see if it's any better. After a lot of experimentation I now run 37 allround. 2012 TDV8 Vogue (L322) | ||
|  1st Oct 2024 12:57pm |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | I've tried this one at 36 psi all round and all the others I've owned.
|  2nd Oct 2024 6:41am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | The servotronic valve/modulator could be partly blocked but they're rather expensive to replace then discover that yours was OK. | ||
|  2nd Oct 2024 8:10am |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | I do need to have a look at the servotronic on this one Graeme, it could be sticky/stuck as you suggest.
|  2nd Oct 2024 5:05pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | There's a very fine gauze filter on the inlet to the valve which could be partly blocked. You could try removing it and at the same time temporarily remove the small o-ring from the valve so that some oil is able to bypass the valve thereby increasing the overall flow. | ||
|  2nd Oct 2024 8:51pm |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | I didnt know about the filter Graeme, does that sit inside the orifice the valve fits in to?
|  2nd Oct 2024 9:09pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | Yes, the little filter is located in the rack neck ahead of the modulator.
|  3rd Oct 2024 9:50am |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758    | Great thank you Graeme, that's given me something new to check.
|  3rd Oct 2024 10:21am |
| Posting Rules
