![]() | Home > Technical (L322) > left/ride play in rear left wheel |
Did you check your front brake shields were firmly attached? One of mine came loose after the mounting holes rusted through and you could only hear the scrapping at low speeds with the window open at first allong with a metalic rattle going over bumps. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2696 ![]() ![]() |
I had a front shield rubbing especially turning left at slow speed a few days ago. I had inadvertently bent the right side shield against the disc when torquing strut bolts 2 days before. |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 418 ![]() ![]() ![]() |
ill give the front shields and back shield a look jic. Its actually a sport |
Rechecked the rear. All good.
Have you checked the rear tail-shaft shields? |
am not sure what they are? Its actually a sport |
Maybe tail-pipes? i.e the heat shields although they tend to rattle when loose. 2012 TDV8 Vogue (L322) |
ive got under there and basically tryed to rattle and "bend" anything away.
a bit extra, seems to only happen under throttle, doesnt occur if am off the throttle and for example try to turn left Its actually a sport |
theres a vid of it here
got her up on jack today
I've just replaced both toe rods as the bushes allowed movement. The balljoints were still OK. |
Unfortunately there are now tie rods on the rear |
No or now? LR call the links from the forward side of the knuckle toe rods as the toe is adjusted by turning the bolt in the bush.
