Home > Technical (L322) > left/ride play in rear left wheel
mgrover
There's this crazy rubbing noise between the above speeds
It's more apparant when turning left at slow speeds it goes away after 20mph
Ive just replaced close to all the rear suspension components so not that.
Do we think front bearings are going/gone?
I can provide a vid but it's not great
Also went around and checked brakes etc etc but seems to only happen on move Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #701529 5th Oct 2024 10:02am
JayGee
Did you check your front brake shields were firmly attached? One of mine came loose after the mounting holes rusted through and you could only hear the scrapping at low speeds with the window open at first allong with a metalic rattle going over bumps. 2012 TDV8 Vogue (L322)
Post #701532 5th Oct 2024 10:20am
GraemeS
Australia
I had a front shield rubbing especially turning left at slow speed a few days ago. I had inadvertently bent the right side shield against the disc when torquing strut bolts 2 days before.
Post #701536 5th Oct 2024 11:30am
mgrover
ill give the front shields and back shield a look jic. Its actually a sport Sad
Post #701559 5th Oct 2024 6:35pm
mgrover
Rechecked the rear. All good.
Brake disc shields are solid and I've cut off the lip
I did notice the rear drive shafts have a tiny bit of play going into the cv joint.
The cv joint into the hub is solid though.
Also I can't hear the rubbing when the windows are open Its actually a sport Sad
Post #701710 7th Oct 2024 5:30pm
GraemeS
Australia
Have you checked the rear tail-shaft shields?
Post #701732 7th Oct 2024 8:48pm
mgrover
am not sure what they are? Its actually a sport Sad
Post #701748 8th Oct 2024 7:51am
JayGee
Maybe tail-pipes? i.e the heat shields although they tend to rattle when loose. 2012 TDV8 Vogue (L322)
Post #701754 8th Oct 2024 9:47am
mgrover
ive got under there and basically tryed to rattle and "bend" anything away.
i dunno why but the noise feels like near the gearbox, but dafuq do i know. Its actually a sport Sad
Post #701755 8th Oct 2024 9:50am
mgrover
a bit extra, seems to only happen under throttle, doesnt occur if am off the throttle and for example try to turn left Its actually a sport Sad
Post #702081 12th Oct 2024 4:24pm
mgrover
theres a vid of it here
around 1:25
https://photos.app.goo.gl/w9m3eBLsdw5aTqPh7
theres a clacking noise at best Its actually a sport Sad
Post #702105 13th Oct 2024 11:39am
mgrover
got her up on jack today
there is play in the rear left wheel left to right
right side is solid 12/6 and 3/9
it seems hub which means bearing.
wtf its a brand new bearing all pressed in to the end and torqued to spec.
hub nut was still the 420nm
can it be anything else? Its actually a sport Sad
Post #702596 19th Oct 2024 3:41pm
GraemeS
Australia
I've just replaced both toe rods as the bushes allowed movement. The balljoints were still OK.
Post #702626 19th Oct 2024 8:41pm
mgrover
Unfortunately there are now tie rods on the rear Sad Its actually a sport Sad
Post #702630 19th Oct 2024 9:57pm
GraemeS
Australia
No or now? LR call the links from the forward side of the knuckle toe rods as the toe is adjusted by turning the bolt in the bush.
Edit: Mine's left bolt had to be cut off between the rear bolt bracket and the bush as the sleeve in the bush had rusted to the bolt. Obviously a new bolt was required.
Post #702640 20th Oct 2024 7:06am
