Home > Maintenance & Mods (L322) > Has anyone replaced the ABS/speed sensor ?
swast4
Hi,
I need to replace the ABS speed sensor on my 02 4.4 RR. It is attached to the hub and slots in with a retaining bolt but it siezed in solid and will require drilling out, but am nervous about drilling this out, any advice ? Do I need to remove the drive shaft ? which I really don't want to do Sad
Thanks..................Adam
Post #70260 28th Jun 2011 6:19am
Why does it need replaced? have you tried cleaning it up?
The driveshaft will need to be split from the hub to allow access Big Cry
Post #70270 28th Jun 2011 8:17am
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Hi,
I have not done one on a RR but did a number on an E39 5 series - possibly the same. The 'soft' retaining bolts do seize and are so soft the allen key cuts the slot smooth. I managed to undo on particular sensor bolt by sawing across the bolt to make a slot and then putting in a chisel/screwdriver and after plenty of WD40 is eventually came undone. My experience of speed sensors led me to always fit genuine sensors not the chinese crud from GSF/ECP and also BBA-Reman are useful for when the Bosche controller goes belly up.
Hope this help.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #70294 28th Jun 2011 10:44am
swast4
I've managed to get the retaining bolt out ok but can't get the sensor out it is stuck solid and have tried with pliers but no joy.
Reason for replacing it, is I have been getting an HDC inactive message coming up because the ABS is showing faulty, all due to the sensor getting damaged or dirty when the drive shaft boot was replaced. The sensor is that mangled or will be when I get it out (if I get it out) that I will need to replace.
It looks like I will have to drill it out, but can I do it in situ ??
Post #70594 30th Jun 2011 6:13am
fisha
It can be drilled out fine. You find as you get the drill into it, it may free up and spin with the drill. Plus if you have your replacement you know how deep you can go
Worth taking a bit of time once it's out to ensure the hub ring teeth are clean and free of gunk V8 or else ...
Post #78023 28th Aug 2011 10:21pm
swast4
Yeh, I managed to drill it out fine using the oild one as a template and put some masking tape on the drill bit to make sure I didn't drill too far.
The problem is I still have the fault, which is sending me demented.
Adam
Post #78285 30th Aug 2011 4:38pm
pretlove
maybe you now need to remove the fault code using a obd tool i had to when i let my brake wear indicator wear all the way down "RANGEISM WILL NOT BE TOLERATED"
Post #78349 30th Aug 2011 8:48pm
fisha
check the cables running up from the abs sensor, up the damper and across to the inner wing ... they can pop out from the clips and be rubbed away by the tyre. V8 or else ...
Post #78749 1st Sep 2011 8:15pm
swast4
Thanks for the suggestion, I have checked the cables already and they are all fine into the inner wing.
I have reset the ABS and steering ECU but have been informed that my geometry maybe out and also need the steering angle sensor recalibrating on testbook. What I've been told is that because it is always happening on steady driving conditions on motorway(or Highway) because the steering wheel is slightly out the car thinks it is going on slight corner but is detecting the speed sensors on each hub are travelling at the same speed.
This seems plausable so am waiting for my wheels to come back from the refurbers before fitting my new rubber, then will get the geometry done and get them to recalibrate the steering angle at the same time or I may ask them to reset steering angle first before geometry so I can figure out what the route casue is, I will report findings when ever my wheels come back.
Adam
Post #80386 11th Sep 2011 1:59pm
swast4
Hi Guys,
Just to report back, finally my fault has been sorted, I have had my tracking done and had my stearing angle sensor calibrated on testbook. 40 pound bill for 3 months of torture trying to sort it out Big Cry
This fault has sent me up the wall ! I have to thank Patrick from GAP diagnostics who helped me get to the bottom of the fault, using the codes read from the IID Tool. (A great bit of kit by the way)
Adam
Post #88958 25th Oct 2011 11:30pm
fisha
Interesting. It must have been out by a fair bit was it?
I had to re-adjust my front end alignments a little due to excessive tyre wear, and the car pulling slightly. It didn't throw up any errors on the ABS beforehand. V8 or else ...
Post #88963 26th Oct 2011 8:55am
petewild
England 2002 Range Rover HSE 4.4 V8 Java Black
I think I have a similar issue, and Id be grateful for any help.
I keep getting the HDC inactive message, along with the the abs and traction amber lights, but its when I turn the wheel full lock left. Full lock right, no issues.
I can sit there for ages with wheels straight, but as soon as I turn the wheel left, BONG
I initially went down the low battery/tracking out remedies, but both are fine and the problem persists.
I left the wheels straight and fiddled with the (I think) the ABS sensor wire, which definitely looks chaffed but not through the cover as to expose wires or anything, and managed to make the fault happen so Im pretty sure that's got something to do with it. I got the Mrs to turn the wheel while I watched the wire at full lock, it seemed to be far too tight and was pulling at either end and BONG the warnings came on.
Thing is, I need to know for sure, whether it is the ABS sensor wire and how easy it is to replace?
The photo is the offending cable, although there are signs of it being chaffed, IE its 'shiny' on part of it, there doesn't appear to be any actual damage, however, fiddling with it causes the error every time.
Id really appreciate anyones assistance here Bow down
Post #248869 17th Mar 2014 10:34pm
