![]() | Home > Maintenance & Mods (L405) > Lumbar support deflates quickly |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
No, I'd say it's leaking |
LT Member Since: 13 Mar 2017 Location: South West Posts: 416 ![]() ![]() ![]() |
I think so. I’ll get it looked at whilst it still has some remaining full warranty. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
It should stay inflated indefinitely sir... |
Thanks. Off to the dealer it is then. |
notty Member Since: 05 Jun 2017 Location: NE Hants Posts: 35 ![]() ![]() ![]() |
Same problem but with approved warranty.
You can but try. If you’re lucky enough to have a good dealer I’d speak to them first. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 403 ![]() ![]() ![]() |
Did you get this fixed? What was required to fix it? Current:
Allegedly it was fixed, but I'm not convinced it was. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1819 ![]() ![]() ![]() |
At my age, I know how it feels……….. |
It's back at the dealers for this same problem. Hopefully this time they'll actually fix it. |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Mighty complicated place to start delving about..
It’s at the dealers still, which is fine as I’ve been abroad and not in a hurry to have it back. A leaking ‘bag’ was discovered and it is being replaced under the extended warranty. |
UPDATE:
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 96 ![]() ![]() ![]() |
I had reason to take mine apart at the weekend - similar to above, the lumbar bag(s) deflated after a few minutes.
