![]() | Home > Maintenance & Mods (L405) > Drivers seat base foam |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8687 ![]() ![]() ![]() |
Sounds like a saga....
Big Vee Member Since: 27 Dec 2023 Location: Lancashire Posts: 21 ![]() ![]() ![]() |
£ 216 |
Thanks, cheaper than I thought... |
From all my searching it’s the same throughout the range apart from cooled or not, then if you recive the correct part |
Well if you’re still interested in the seat foam saga read on..
Getting there.... Pete
Geo Member Since: 04 Apr 2023 Location: South East Posts: 16 ![]() ![]() |
Thanks for sharing, another job I keep meaning to get around to! |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 402 ![]() ![]() |
My only complaint about my L405 is the uncomfortable seat base. It was the same when I bought it at 50 odd k miles. Never had that issue with the L322.
Thought I'd give an update, under the seat foam pad there is a sprung metal frame but unfortunately not sold separately, in my madness I removed the passenger seat and swapped them over as identical and seen a lot less of someone's fat arse.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
When you diisconnect the battery the car sends a message to the incontrol centre and they log it. You have to contact them to let them know it was you who wasn’t stealing the car. I had the same at the weekend, I got a text from them letting me know the car had been stolen (me disconnecting the battery on my drive!) 30 seconds later call later and the suspended the monitoring for an hour and reset the app.
Northern monkey,
Actually took two phone calls 1st time 90% progress, second time sorted. |
