Home > Off Topic > mapp gas torch blowing out
can someone steer me in the right direction to solve a problem with my mapp gas torch blowing out.
the gas cannister is new and has been kept in a relative warm place..the torch bit is also new..
i use it to melt gold/brass and it gets to a certain point and then blows out...i have the cannister at a 'horizontal to tipping down' level and the melting material is in a small crucible..
any ideas ? ... - .- -.
Post #703960 7th Nov 2024 2:01pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Stan, I think it needs to be more vertical, you want to burn gas not liquid.
That's how my torch works.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #703961 7th Nov 2024 2:06pm
so do you think the liquid is stopping the gas from coming out evenly? ... - .- -.
Post #703969 7th Nov 2024 2:47pm
bigbo
That's what I was thinking, but I'm wrong.
I just had to nip to my workshop to get some tools so I tested my torch and it works i any direction. So sorry about that. It must be my plumbers torch on butane that doesn't work upside down.
So I don't know what is wrong, but as they are both new I would take them back. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #703972 7th Nov 2024 3:04pm
much appreciated...i'm waiting for my supplier to come back and to see what they say.. ... - .- -.
Post #703973 7th Nov 2024 3:09pm
JCW
My MAP gas torch does the same Stan, works perfectly when vertical to horizontal but tipping it over further, i.e. more upside down and it tends to go out. I just work around it but good to know if there is a solution or just the way they work. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #703977 7th Nov 2024 3:53pm
Merchy
Melting gold ? have you got a new dodgy side job on the go Stan Shocked
Has your SIWMBO carried out an inventory of her jewellery lately Rolling with laughter
Post #703981 7th Nov 2024 4:30pm
Laughing
she does wonder why i offered to clean her wedding rings...
@jonathan, thanks for the confirmation...googling suggests the liquid in the bottle blocks the gas coming out... ... - .- -.
Post #703985 7th Nov 2024 5:02pm
What torch have you got Stan, I’ve got a rothenberger super fire 2 and use it mostly on Mapp and it works any way up. 🤷‍♂️
You can get flexi torches with a bendy head on them if you need it to point one specific way but want to keep the bottle up. There is nothing that can't be fixed with a hammer😜😜
Post #705673 28th Nov 2024 10:02pm
i am ashamed to report that the 2 torches i have are cheap ebay jobbys... Embarassed
most likely why they dont work properly.. ... - .- -.
Post #705674 28th Nov 2024 10:25pm
Kot
Without doubt you are allowing liquid to exit torch. Its a gas burner, hold the cylinder vertical this allows only gas to exit! 2018 SE SDV8 4.4 Byron Blue
Post #705679 28th Nov 2024 11:44pm
That makes sense using my cheapy torch heads but it sounds like Marks 'proper' one is ok... ... - .- -.
Post #705685 29th Nov 2024 9:10am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I have two different torches, one with a pencil flame I use on brake pipe connections and the other for plumbing jobs which started flairing up after purchase a new cylinder, after swopping cylinders about it's down to the cylinder so only I would say is try a different cylinder, as an aside had to sign in on my phone for this reply and boy is it hard work! (It's an age thing)
Post #705750 30th Nov 2024 1:01am
Yep, very old “proper” one Stan….. they seem to be stupid money at the moment. Was looking to replace it recently with a new one as the trigger is iffy and the flow control knob is fubar but will solder on with it for a bit longer.
I use the rothenburger gas as well with them, never had an issue.
Post #705772 30th Nov 2024 1:15pm
