![]() | Home > Off Topic > mapp gas torch blowing out |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35857 ![]() ![]() |
can someone steer me in the right direction to solve a problem with my mapp gas torch blowing out.
so do you think the liquid is stopping the gas from coming out evenly? ... - .- -.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 613 ![]() ![]() ![]() |
That's what I was thinking, but I'm wrong.
much appreciated...i'm waiting for my supplier to come back and to see what they say.. ... - .- -.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 956 ![]() ![]() |
My MAP gas torch does the same Stan, works perfectly when vertical to horizontal but tipping it over further, i.e. more upside down and it tends to go out. I just work around it but good to know if there is a solution or just the way they work. Jonathan
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Melting gold ? have you got a new dodgy side job on the go Stan |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
What torch have you got Stan, I’ve got a rothenberger super fire 2 and use it mostly on Mapp and it works any way up. 🤷♂️
i am ashamed to report that the 2 torches i have are cheap ebay jobbys... |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
Without doubt you are allowing liquid to exit torch. Its a gas burner, hold the cylinder vertical this allows only gas to exit! 2018 SE SDV8 4.4 Byron Blue |
That makes sense using my cheapy torch heads but it sounds like Marks 'proper' one is ok... ... - .- -.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 228 ![]() ![]() ![]() |
I have two different torches, one with a pencil flame I use on brake pipe connections and the other for plumbing jobs which started flairing up after purchase a new cylinder, after swopping cylinders about it's down to the cylinder so only I would say is try a different cylinder, as an aside had to sign in on my phone for this reply and boy is it hard work! (It's an age thing) |
Yep, very old “proper” one Stan….. they seem to be stupid money at the moment. Was looking to replace it recently with a new one as the trigger is iffy and the flow control knob is fubar but will solder on with it for a bit longer.
