Home > Technical (L405) > L405 FBH Telestart Receiver Fob Pairing - Solved
Page 4 of 5 <12345>
Justin017
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Was off a 2020 and googling it seems to be a T91R - no idea what the r means but maybe I’ll just eBay it and buy the one you suggest and give that a go!
Post #587411 14th Mar 2021 10:24am
Justin017
On my build log (from using the VIN decoder) I have this...
Engine Pre Heater - No Engine Pre-Heater [043BC]; Park Heating - Park Heating With Remote Control [043AV];
Heater Unit Operation - Fuel Burning Heater [043AB];
Does this mean I should definitely have a fob or did the early L405's only have the option to set timed climate from within the car.
Would also be cool to know if the InControl App should work with my car.
Post #587526 15th Mar 2021 10:45am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
You should definitely have a fob. However, the InControl App functionality for the FBH only came in on 16MY AFAIK.
Post #587749 17th Mar 2021 9:42am
GG.
United Kingdom 2019 Range Rover Vogue SE SDV8 Loire Blue
Hello all - new to here but hoped one of you may have some experience on this...
I picked up a 3 year old 2019MY SDV8 L405 just prior to Christmas and am thoroughly confused by the FBH. The spec sheet printed from Topix says I have one on the car and sure enough I can see the Webasto unit nestled in the top left corner of the engine bay.
But... there is no menu for timed climate on the infotainment system and no remote fob to operate it from outside the car. I'm not really bothered about the timed climate as I don't commute in it but would like the fob.
I talked to LR and they were predictably unhelpful and said the car didn't come with a fob and I could use incontrol to pre-heat, which isn't the same thing as it starts the car and part of the point of the pre-heater is to warm the block through prior to starting.
Does anyone know if you can retrofit a FBH fob to a facelift L405 or will it now not have the Webasto telestart module/aerial fitted? And if not, can I add that module plug and play to a facelift model or would the wiring have to be fiddled with?
Cheers!
Post #623265 11th Feb 2022 10:58am
Inigo
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Corris Grey
I've recently picked up a MY2019 SVA. Petrol and has a Webasto fuel burning heater under the bonnet. The build sheet said: Fuel Operated Heater + Timer + Remote.
I have timed climate available via the screen, but no fob. I have a fob, receiver and aerial removed from my Discovery 4, but cannot get the fob to pair with the L405. Feeling about under the D-pillar, it feels as though the receiver is in place.
Do I need to buy a different fob, and if so, which one for MY2019, petrol Webasto?
Post #700085 13th Sep 2024 11:09pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
The L405 has an Eberspacher FBH, not a Webasto.
Post #700149 15th Sep 2024 4:01pm
Arch Stanton
I'm pretty sure my L405 2018MY has a Webasto... Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #700153 15th Sep 2024 4:35pm
Fifth Horseman
It changed from Eberspacher to Webasto from 2018MY
Post #700178 16th Sep 2024 12:09pm
hmallett
I stand corrected! So from Webasto on the L322, to Eberspacher on the L405, then back to Webasto!
Post #700182 16th Sep 2024 3:26pm
Nabbler
Wales
Hope this helps this is the fob from a 21My SVA petrol.
 2025 SV P615
2021 SVautobiography Dynamic Black ( gone )
1997 C140 Mercedes Benz CL500
Post #700185 16th Sep 2024 4:39pm
Nabbler
Wales
And how to pair the fob to the car.
?si=f7w5NbIdorQzQnwI 2025 SV P615
Post #700186 16th Sep 2024 4:44pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
i need a remote fob for my 2014 l405 dose anybody have a part number by any chance ?
thanks
Post #703979 7th Nov 2024 4:15pm
E500
I bought this for my 2015 and it paired fine.
https://tpuk.net/land-range-rover-sport-ev...y-fob.html
Post #703990 7th Nov 2024 5:43pm
will308f
yea looks the same as mine , ran through the pair process but all i get is just a flashing red led or flashing green led so don’t know was thinking i had the wrong remote
Post #703997 7th Nov 2024 6:11pm
E500
That looks different to my fob, I have a Dec 2015 MY16 car. Have you checked what heater you have under the bonnet? I thought the pre-facelift cars, ie yours and mine, all had the same heater and they changed it for the Webasto(?) at or around facelift time.
Post #703999 7th Nov 2024 6:47pm
Page 4 of 5 <12345>
