Home > Technical (L405) > L405 SDV8 intermittent starting problem
niklasel
Sweden 2014 Range Rover Vogue SDV8 Causeway Grey
My L405 SDV8 low mileage (18.600 miles / 30.000 km) had a B service (oil + fuel filter change) done a month ago. Service history is as per recommendation although with the low mileage not done every year. Last time for fuel filter change was 2018.
After the service, I have an intermittent starting problem where the car cranks but won't start. Error code Low Fuel Pressure (P0087). Initial idea was that the in-tank fuel pump was dead and it was replaced after the car did not start any longer (apparently a not uncommon issue). Power supply was checked and pressure measured at the fuel filter seemed low.
The problem, however, persists. It is regardless if the engine is hot or cold. Every 20 start is a crank but no start. Oftentimes when driven and then left for 10 minutes. It simply won't start. If it starts, the engine does not idle well and then stops after 5 seconds with error code Low Fuel Pressure. Engine light is then turned on but disappears after 2 days.
The idea now is that it might be the fuel pressure regulator on the manifold. The latter is apparently also a not uncommon issue. We've ordered a new one in combination with secondary fuel pump and pressure sensor on the manifold.
I hear a humming sound from the secondary fuel pump and I guess it might be blown as well from the fuel pressure regulator not being able to close 100% or at least from time to time doesn't. The noise started when (I think) the in-tank fuel pump collapsed.
My guess is that the fuel filter was blocked after 6 years of no change, and potentially in combination with the regulator not closing 100%, destroyed both fuel pumps. Potentially, only the regulator was the issue. It probably happened before me and the seller never informed me. When I needed to engage N for towing to the workshop I saw the lever wasn't fastened down and hence I guess it had happened intermittent before.
Any other idea is most welcome!
Post #704023 8th Nov 2024 10:02am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Is there a way of checking the actual fuel pressure with a gauge? I don't know if there is but that's where I'd be headed in an effort to avoid throwing parts at it!
I do like Stockholm!
Chris
Post #704065 8th Nov 2024 4:21pm
niklasel
Yes there is a fuel gauge where the filter is situated. But then I need to drive around with it attached along with decoding equipment etc. I was hoping to avoid buying equipment and tools but maybe that’s what Land Rovers are all about (trouble shooting) Laughing
Post #704067 8th Nov 2024 5:13pm
Happydaze
I was envisaging a simple, capillary type gauge, or a vac /pressure gauge, which is a very useful, cheap diagnostic tool, nothing special!
Chris
Post #704102 8th Nov 2024 10:31pm
niklasel
update
So now the secondary auxiliary fuel pump died as I expected. The humming sound was gone one morning and the car started but gets no fuel and eventually dies. Workshop ordered a pump in Oct but it never came so I ordered one myself now. Due to arrive shortly. Will try to replace it myself although it looks pretty tight down there under the ECM. Any tips here?
It's more than 2 months without a proper functioning car now. So miserable.
I think the in-tank pump died which killed the secondary pump which ran dry / overheated.
Workshop still claims it could be the fuel pressure regulator. Will probably replace that one too.
Hate this car.
Post #706147 5th Dec 2024 11:39am
niklasel
finally!
The auxiliary secondary fuel pump OEM (from Hella) arrived on Fri 6.12 and today I installed it myself. Original part was a polish brand.
Quite tight down there but no need to remove the panel (secondary bulkhead left panel) as the workshop manual suggests. Clamp size is 12-14mm. Most clamps are quick release. Also, do not remove the auxiliary fuel pump nuts (2 of them) but rather remove the entire panel (3 nuts) as they are fix welded. The 2 pump nuts are not and starts to spin and you need to hold the screw on the backside of the panel (not possible). Rubber protection came off easily with silicon lubricant.
It starts and runs smoothly. Much better response from the throttle. So happy that I fixed it myself.
Let's see if the intermittent starting problem persists. Will replace the fuel pressure regulator then.
Post #706326 7th Dec 2024 4:49pm
Well done, a satisfying outcome, are you loving it a bit more now..? Pete
-Click here for Thread-
Post #706331 7th Dec 2024 5:35pm
niklasel
As long as it runs I love this car. I guess a low mileage car would suffer from the nowadays “healthy” diesel provided. Not sure the additional work creates less CO2 emissions eventually.
Post #706338 7th Dec 2024 6:42pm
niklasel
new update
So I ran the car for an hour now and noticed that the secondary pump became louder and louder. I opened the fuel cap and there was a substantial vacuum.
2 new pumps but something is still wrong. Is there something wrong with the return line? Can this be the fuel pressure regulator? If it's leaking, the HPFP might have to run really fast and thus put pressure on the auxiliary LPFP.
Really would appreciate someone who really knows the system here. Big Cry
Post #706383 8th Dec 2024 12:03pm
cass
Have you checked the vent in the filler cap?
Post #706384 8th Dec 2024 12:09pm
niklasel
I ran the car without the filler cap and the noise is still there... this issue came just some weeks ago. Can't imagine the cap is the issue all of a sudden. This car is almost brand new. Zero dirt anywhere.
I think the new pump is already blown... Big Cry
Post #706388 8th Dec 2024 1:14pm
niklasel
update
I drove the car to the most renowned LR dealer in greater area Stockholm and they said the car is fine. No issues. Loud buzzing sound from auxiliary fuel pump is due to pump being OEM and not LR original they claim. OEM pump from Hella. Absolutely not sure here but who knows.
I now ordered a new original pump and let's see if the humming stops. LR offered the change at 1.2kEUR incl. part but I ordered the genuine pump for 0.2kEUR. Need to buy Christmas presents. Laughing
Since no one answers these posts with some insights I conclude that people either don't fiddle around with the L405's much or this is a very unique problem.
At least, since I replaced the pumps the car always starts.
Post #707198 18th Dec 2024 6:21pm
niklasel
solved!
With the genuine fuel pump installed the car is back to normal. What a waste to trust Rimmerbros and other dealers with the OEM pump. Next time I’ll go genuine unless it’s obvious that an OEM part can do the job. Hurray!
Post #708119 2nd Jan 2025 4:50pm
Glad you got it sorted, genuine is the way to go with a lot of parts if you can afford it... Thumbs Up Pete
Post #708123 2nd Jan 2025 5:39pm
Flash
Sweden 2015 Range Rover Autobiography SDV8 Kaikoura Stone
As it seems Niklasel solved his issue I'll test and reuse this thread.
For the first time since I bought my 2015 SDV8 L405 it just stopped while driving in the city and wouldn't start. After the third try it started again and worked as usual. No messages in the cluster. Haven't checked for error codes yet.
I guess this could be a fuel pump issue on its way. What else than lack of fuel would make a diesel just stop? (Maybe a stupid question on a Range Rover...)
Post #717820 12th May 2025 6:22pm
