Home > Wheels & Tyres > Does DK62-1007-DB (rfom 2017 RRS) work on 2017 FFRR?
bdd123
United States 2017 Range Rover Autobiography 5.0 SC V8 Aintree Green
Looking for 20" to put AT tires on my 2017 FFRR ATB.
Can someone confirm that these wheels will work "plug and play".
What tires are you running on this wheel or other 20x8.5 wheel?
Does spare tire fit in stock location?
Do you experience rubbing when turning?
Do you experience rubbing at access height?
Any other helpful insight?
 Current: 2017 L405 ATB, 2016 LR4 SE
Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1
Post #704309 12th Nov 2024 4:52pm
Vogue
Took a bit of finding - but here is a hard example :-
https://www.fullfatrr.com/forum/topic20116...p;start=45
Bottom of the page emperor mongs post 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704331 12th Nov 2024 7:27pm
Vogue
And yes 285/50/20 Cooper AT’s do fit without any issues whatsoever - no rubbing in off road, std or access modes - I have a set of them on mine now for the winter shooting season 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704332 12th Nov 2024 7:29pm
Vogue
Different wheels from yours and Emperor Mongs - but you can see that size fit no issues and what they look like 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704333 12th Nov 2024 7:31pm
bdd123
Thank you. Since all is go I would assume that tire would also fit in spare spot? Current: 2017 L405 ATB, 2016 LR4 SE
Post #704375 13th Nov 2024 4:58pm
Vogue
yes - I know others have had to deflate slightly depending on model spec and year - I have fitted in both my V8 Diesels though. Bare in mind the RRS wheels have a slightly different offset - which may help or not 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704378 13th Nov 2024 6:04pm
maxbasscat
England 2016 Range Rover Autobiography SDV8 Carpathian Grey
Maybe the angle of the photo but OP photo looks a different wheel altogether Whistle
Post #704388 13th Nov 2024 9:12pm
Gremlin500
Maxbasscat is correct! Twisted Evil
Not the same wheel I’m afraid, Vogue Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #704389 13th Nov 2024 9:21pm
Tdtj
In vogue’s photo he does specify its a different wheel 2016 4.4 diesel
2019 4.4 diesel
Post #704390 13th Nov 2024 9:25pm
Gremlin500
Ah, yes my bad, he’s only referring to the diameter, are they the same offset, though? V6 Vogue - “Less is More” - less to go wrong!
Post #704391 13th Nov 2024 9:38pm
Vogue
No, as I said the offset is different - the RRS wheels have less offset so they stick out very slightly more - I have no idea if this will affect them fitting in the spare wheel well as I haven’t got any. The OEM FFRR wheels do though 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704393 13th Nov 2024 10:13pm
maxbasscat
Check load rating
Indeed Vogue does caveat....my alert is I have the same wheels as OP and I fitted them to my L405 and removed them as I felt they may not have the same load rating or offset. I intended to get my L405 21" refurbished. Being aware of insurance issues on Discovery & FFRR rims I have a view that if the OP rims are suitable then why did LR give options as below Style 502 or 504? Hence I was concerned on loading rating in particular.
I am not sure but think my 20" were off a RRS (L320) unusually for a RRS rim they have 255/55/20" fitted rather than 275/50/20". When I can access the photo I will post as they do look similar to the 20" Style 502 (well nearly) and more akin to the 22" Style 504 so just for bdd123 to note to be cautious before buying
Post #704394 13th Nov 2024 10:19pm
Vogue
Load rating should be fairly easy to check as all the recent RR wheels I have seen have the load rating engraved on the inside of the rim. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #704395 13th Nov 2024 10:51pm
