![]() | Home > Wheels & Tyres > Does DK62-1007-DB (rfom 2017 RRS) work on 2017 FFRR? |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
Took a bit of finding - but here is a hard example :-
And yes 285/50/20 Cooper AT’s do fit without any issues whatsoever - no rubbing in off road, std or access modes - I have a set of them on mine now for the winter shooting season 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| bdd123 Member Since: 27 Apr 2024 Location: Colorado Posts: 15
Thank you. Since all is go I would assume that tire would also fit in spare spot? Current: 2017 L405 ATB, 2016 LR4 SE
yes - I know others have had to deflate slightly depending on model spec and year - I have fitted in both my V8 Diesels though. Bare in mind the RRS wheels have a slightly different offset - which may help or not 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| maxbasscat Member Since: 11 Jun 2016 Location: South Cambs Posts: 43
Maybe the angle of the photo but OP photo looks a different wheel altogether |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1890
Maxbasscat is correct! |
| Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 208
In vogue’s photo he does specify its a different wheel 2016 4.4 diesel
Ah, yes my bad, he’s only referring to the diameter, are they the same offset, though? V6 Vogue - “Less is More” - less to go wrong! |
No, as I said the offset is different - the RRS wheels have less offset so they stick out very slightly more - I have no idea if this will affect them fitting in the spare wheel well as I haven’t got any. The OEM FFRR wheels do though 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Indeed Vogue does caveat....my alert is I have the same wheels as OP and I fitted them to my L405 and removed them as I felt they may not have the same load rating or offset. I intended to get my L405 21" refurbished. Being aware of insurance issues on Discovery & FFRR rims I have a view that if the OP rims are suitable then why did LR give options as below Style 502 or 504? Hence I was concerned on loading rating in particular.
Load rating should be fairly easy to check as all the recent RR wheels I have seen have the load rating engraved on the inside of the rim. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| All times are GMT |
