![]() | Home > My Range Rover > 5 RRs and I have to give up |
| MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758
Okay so we're saying it's probably not the pipes, the pumps new, the resevoir is new, the cooler no longer leaks and the servotronic valve checks out OK. (We think)
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
I agree with GraemeS, you've eliminated the Servotronic valve.
Afternoon Pawl,
Graeme, I just read your post via search regards your steering becoming heavy post input seal replacement.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2783
Yes, grit had found its way into the pump and caused the valve piston to stick open thus providing almost no pressure. Once freed, power assist was working again. |
Excellent result Graeme, well done that man |
Okay, so I've had it up in the air today to check for binding.
I have a little bit more to add.
I think the "error" might be because the BCM outputs a PWM (Pulse Width Modulation) signal - effectively pulses of voltage to drive the Servotronic valve. The gaps between the pulses reduces as the vehicle speed reduces, so that the valve opens more. 12v is being applied - but not continuously.
I completely understand what your saying Pawl regards measuring PWM (continous on/off pulse) signals but it seems a bit redundant for LR to include this data PID in the software if its unable to read anything.
With the connector unplugged from the valve and with the engine running but the vehicle not moving, is the steering quite a lot heavier than with the connector fitted? However, I think that you've already tried this and found the steering ligher when connected. |
Well today has been a very strange day indeed...
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
amazing RR 2005 4.4 petrol
Still driving okay today |
| All times are GMT |
