![]() | Home > Maintenance & Mods (L405) > Help - Suspension fault Green & Yellow |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
That's a shame, you'll probably be doing this then....
Don't be tempted to run it with a leak, if the pump runs dry you will have an even bigger bill... |
bigdave Member Since: 27 Jun 2011 Location: Cornwall Posts: 268 ![]() ![]() ![]() |
Yeah the chaps said that.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I had the very same issue, and had the front ACE pipes replaced a few weeks ago, after waiting for parts for several months.
Oh god dont say that!! |
My front pipe went first, the rear started leaking as I brushed past it....?
Great!!
If you have the four way climate then get the rear pipes checked as they rot as well and run under the rear subframe, be a small amount to replace them if you are doing the lot....
Yes indeed i do.
May as well, mine were all done a couple of years ago so still good... Pete
Struggling to find the pipes to be honest.
Depends where yours have leaked, mine were fine going into the manifold, they rusted through near the wheel arch...
Thanks Pete,
I may have found the parts i need in Vancouver.
