Home > Maintenance & Mods (L405) > Help - Suspension fault Green & Yellow
Page 2 of 3 <123>
That's a shame, you'll probably be doing this then....
https://www.fullfatrr.com/forum/topic67828.html Pete
-Click here for Thread-
Post #704735 18th Nov 2024 6:34pm
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Thanks Pete,
Very comprehensive sir but sadly im the sort of person that sends the car in if the ashtray is full.
I took it to the indy yesterday and they said the front pipes are shot. Rears are ok.
there is a lead time on the parts and they re all booked up for a month so im stuck with a lame duck.
Luckily i work from home and have no major travel plans so will be patient.
Gutted doesnt come close but i had a D3 back in the day so not surprised really.
Thanks for your help bud this and the D3 forum are always life savers!!
Cheers.
Post #704998 21st Nov 2024 11:17am
Don't be tempted to run it with a leak, if the pump runs dry you will have an even bigger bill... Shocked Pete
Post #705032 21st Nov 2024 1:09pm
bigdave
Yeah the chaps said that.
They said no long runs and if i have to pop out i half a couple of litres of fluid to top the reservoir.
Happy days!!
Big Cry
Post #705033 21st Nov 2024 1:11pm
I had the very same issue, and had the front ACE pipes replaced a few weeks ago, after waiting for parts for several months.
Sadly, it seems that when the front ones go, the rears aren't far behind Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #705035 21st Nov 2024 1:31pm
bigdave
Oh god dont say that!!
Post #705118 22nd Nov 2024 11:38am
My front pipe went first, the rear started leaking as I brushed past it....?
Maybe worth seeing how much they want for both done separately or together, it maybe worthwhile to do them both although they are sort of totally separate jobs, one things for sure, it will fail... Crying or Very sad Pete
Post #705135 22nd Nov 2024 2:31pm
bigdave
Great!!
Ironically they said they had the rears in stock!
This is going to test my bank account and my nerves.
Big Cry
Post #705142 22nd Nov 2024 3:28pm
If you have the four way climate then get the rear pipes checked as they rot as well and run under the rear subframe, be a small amount to replace them if you are doing the lot....
Then your done with them for another 8 odd years....
Thumbs Up Pete
Post #705153 22nd Nov 2024 5:49pm
bigdave
Yes indeed i do.
Sounds like a good idea.
If the rear subframe has to come off is it worth doing the brake flex hoses too?
May as well get as much done then hope she behaves for a few years. (LOL)
Thanks for all the advice so far.
Dave
Thumbs Up Thumbs Up
Post #705177 22nd Nov 2024 9:13pm
May as well, mine were all done a couple of years ago so still good... Pete
Post #705333 24th Nov 2024 3:17pm
bigdave
Struggling to find the pipes to be honest.
Even my contact in Kuwait has them on country wide back order since October.
So what do you think on the repair kit;
https://ebay.us/t7juBM
Thanks.
Dave
Post #705608 28th Nov 2024 9:52am
Depends where yours have leaked, mine were fine going into the manifold, they rusted through near the wheel arch...
If I couldn't get the pipes from JLR, and that kit was no good then I think I would have taken them off and dropped them at a hydraulic line shop and have them make up some pipes in braided hose, you would then have to find a way to fix them better and stop slap in the hose when the pressure ramps up...
 Pete
Post #705694 29th Nov 2024 11:00am
bigdave
Thanks Pete,
Way beyond my capabilities im afraid.
Im awaiting a response from the garage about the temp solution.
Appreciate all your help Sir.
Dave
Post #705717 29th Nov 2024 5:31pm
bigdave
I may have found the parts i need in Vancouver.
However they drive lefties over there so does anyone know if th set up is the same or not.
Many thanks.
Dave
Post #706068 4th Dec 2024 8:47am
Page 2 of 3 <123>
