![]() | Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 752 ![]() ![]() |
Thanks David,
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 800 ![]() ![]() ![]() |
in my opinion, if air is getting in, which i doubt, there must be a restriction between the reservoir and the pump.
Great thoughts Knares,
Well, it's been consistently... awful today.
More late night messing,
Can someone with suitable diagnostics and a 2006-2009 pre LCD dash L322 please check this out for me?
So for anyone still reading, I've just done the test where I feed 12v direct to the servotronic valve bypassing the BCM output.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Yes we are still reading, thinking back to when Haylands drove your car, a thought struck me. I have only ever driven my 2006 td6 and my 2007 Tdv8 3.6, and will admit there are days when I think the suspension has become a little 'crashy' and response seems to have been 'dulled down' then the next day I climb in and the car(s) seems sublime in handling and response.
My original RR was great during its first year with me, it always drove great and felt consistent.
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
I don’t know if this information is useful but someone with a current generation Mini had all sorts of driveability issues including intermittent strange steering and the fault was cured after fitting a new outside temperature sensor . There are of course many sensors can cause issues . |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6816 ![]() ![]() ![]() |
Maybe time to go back to Bentley? |
@MarianaW I have an IcarSoft tool... BUT... it is currently on loan to a friend, will try to get it back and have a look at the values before I go back to sea |
That would be very helpful and most appreciated Merchy, thank you.
The temp sensor is probably ok if it shows the correct temperature |
