Home > Technical (L322) > Please help!!! Really stuck now...
Ma Larkin
United Kingdom 2012 Range Rover Westminster TDV8 Barolo Black
RR 2012 4.4 tdv8. About 3 weeks ago it just cut out. A few weeks before that we noticed it spluttered a bit, for a few seconds and that was it. When it cut out, we had the fault code p0088.... replaced all common sensors, checked low pressure system etc. Fuel was getting to high pressure pump but not coming out. As luck would have it, family member had a brand new genuine pump for his (now sold) RR and so we replaced. All timed correctly. Changed CKP sensor too for good measure. Everything that could be changed has been changed (bar injectors..) Still wont go!! We have been advised that that there may be a fuel lockout, which should be reset. However we can not find how to do this. Apparently it is done through the ECM/ECU software. There is no option on the iid tool, and certainly no manual inertia switch. Please can anyone shed any light? Fuel input still says 0... Many thanks in advance
Post #706870 14th Dec 2024 6:26pm
Scouse Exile
Call me stupid but … have to you cycling the ignition a few times before attempting to start it?
Just a thought but suspect you’ve done it.
J
Post #706871 14th Dec 2024 6:41pm
Mikey
Do you still have the same fault codes returning?
Post #706872 14th Dec 2024 6:43pm
Ma Larkin
No! Threw up P0194-00 and P250a-92 but they have been cleared now too. It's all a bit strange
Post #706874 14th Dec 2024 6:49pm
Ma Larkin
J
Def not calling you stupid! ANY suggestions at this point is really helpful, and it usually is the simplest things which get over looked. But, yes. Tried that.
Post #706875 14th Dec 2024 6:52pm
GraemeS
Australia
Have you investigated the electrical connector referenced on LTB01083 which is for P0088-17?
Post #706894 14th Dec 2024 11:48pm
Ma Larkin
Yes. That was one of the first things we did. Honestly don't know where to go now...
Post #706899 15th Dec 2024 8:17am
GraemeS
Australia
Presumably the original connector was replaced or bypassed rather than just checked.
Post #706900 15th Dec 2024 8:24am
Ma Larkin
Yes. We bypassed it. Cut the plug out and joined the wires.
Post #706901 15th Dec 2024 9:54am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Not sure if same problem but see link:
https://www.fullfatrr.com/gallery/albums/u...B01083.pdf
A modified link lead to the fuel pressure sensor cured my problem of spluttering and hesitation
A fairly cheap fix….
Post #706916 15th Dec 2024 12:23pm
toby1
Interesting and I wonder if this is linked to my issue? I shall check my harness. 2012 Vogue TDV8 in Aintree green over sand
Post #706925 15th Dec 2024 12:58pm
Ma Larkin
We did this as one of the first things. Still no difference to ours.
Post #706926 15th Dec 2024 1:07pm
Rambles
Could be a new fuel sensor is needed then …
Post #706932 15th Dec 2024 2:24pm
Ma Larkin
All sensors changed....
Post #706938 15th Dec 2024 2:52pm
kevinp
Clutching at straws, but have you had a look at the condition of the fuel filter?
Post #706943 15th Dec 2024 3:11pm
