![]() | Home > Technical (L322) > Please help!!! Really stuck now... |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 406 ![]() ![]() ![]() |
Call me stupid but … have to you cycling the ignition a few times before attempting to start it?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1838 ![]() ![]() |
Do you still have the same fault codes returning? |
Ma Larkin Member Since: 14 Dec 2024 Location: hampshire Posts: 11 ![]() ![]() ![]() |
No! Threw up P0194-00 and P250a-92 but they have been cleared now too. It's all a bit strange |
Def not calling you stupid! ANY suggestions at this point is really helpful, and it usually is the simplest things which get over looked. But, yes. Tried that. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2711 ![]() ![]() |
Have you investigated the electrical connector referenced on LTB01083 which is for P0088-17? |
Presumably the original connector was replaced or bypassed rather than just checked. |
Yes. We bypassed it. Cut the plug out and joined the wires. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 832 ![]() ![]() |
Not sure if same problem but see link:
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 272 ![]() ![]() |
Interesting and I wonder if this is linked to my issue? I shall check my harness. 2012 Vogue TDV8 in Aintree green over sand |
We did this as one of the first things. Still no difference to ours. |
Could be a new fuel sensor is needed then … |
All sensors changed.... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1320 ![]() ![]() ![]() |
Clutching at straws, but have you had a look at the condition of the fuel filter? |
