Home > My Range Rover > My 2012 Westminster TDV8
Page 3 of 5 <12345>
RobsterPC
A few quick jobs today.
First, upgrading the reverse lights. I like the stock look but not the performance so I bought some replacements from Classic Car LEDs. Too early and light to see if they improve things but they were only £15 posted. 5 minutes to unscrew the units and swap the bulbs.
Next up, sorting out the main ICE screen. After some advice on here, baby wipes took the screen from this
To this
This job took about 10 minutes, getting into the edges is tricky.
Finally, the only code I couldn't clear has been the left side mirror showing a short circuit. I fitted a new mirror glass and reset the codes, all cleared.
Post #705227 23rd Nov 2024 2:55pm
RobsterPC
New high and low beam bulbs on order, hopefully they'll get fitted this week.
I've had a low coolant warning pop up. I've topped off the coolant but this points to a leak somewhere. Its going in for a transmission flush on Friday and they'll check it over for me then. I suspect the EGR valve or similar, hopefully nothing too pricey.
I've also got a little deflated about the drivers seat cushion foam (see what I did there?) so I've ordered a new foam pad. Once its back from the flush I'll pull out the drivers seat and replace the foam as well as the (probably) cracked seat blower pipe too. Hopefully a more comfy and warm seat awaits!
Post #705925 2nd Dec 2024 6:14pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi Robster,
Where did you get the seat squab foam from ? Mines going a bit flat and am looking to replace it or steam it, I'll replace if it's cheap enough.
I'm not sure if they are the same as the vogue because I've heard they're supposed to be a bit firmer than the AB seats,
Cheers
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #705943 2nd Dec 2024 10:31pm
RobsterPC
Part LR009645
I got it from Jaguar Land rover Classic, it's OEM as I can't find any alternatives. Not cheap but everywhere seems to be the same price. If it's done 136k miles on this one then I'm sure it will do me just fine.
Post #705949 2nd Dec 2024 11:42pm
dhallworth
Would be interested in pictures of how easily the seat foam can be replaced if you don't mind! I'd be tempted to do my drivers side one on the 5.0 as the seat isn't quite as good as the 26k mile 4.4 TDV8 we've got. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #705952 3rd Dec 2024 1:43am
RobsterPC
Yes, I'll share some pictures as it happens, assuming I don't damage myself removing the seat! The workshop manual has a section on this too:
Post #705970 3rd Dec 2024 10:49am
AndyRoo
Cripes that's a bit pricey, I' think I'll have a go at steaming first after I strip it down.
Cheers for the info.
Post #706028 3rd Dec 2024 6:04pm
RobsterPC
Currently in for a gearbox mega flush and investigation of leaking coolant. Apparently the thermostat housing is leaking. Not looking forward to the bill for this one.
Post #706240 6th Dec 2024 12:38pm
RobsterPC
Gearbox flush done and coolant leak investigated at Dartford Transmissions. They also gave it a good going over but didn't report any more faults, which was good as it was a punchy bill! The gearbox definitely feels smoother now when cold, less clunky when pulling away. It had done 30k miles since the last gearbox oil change but that was not a full flush.
Coolant leak was the lower thermostat housing, that's all been replaced so hopefully that's one less coolant leak to worry about for now.
Post #706783 13th Dec 2024 5:08pm
RobsterPC
I love the easy jobs. Before I tackle anything else I wanted to improve the headlights. Time for some Osram Xenarcs for the low beam and some Bevinsee V55s for the high beam. Both from AliExpress.
Old main beam units compared the LED ones. Being LEDs, you need to get the connector the right way round. Brown to + and red/black to -.
The low beams were already Osram Xenarcs bit looking a little crusty and one had shattered. Possibly when taking it out but I couldn't tell.
Lights on the left are old, right is new
Job completed. About 10 minutes and the hardest part was getting the caps off to get access to the bulbs.
Post #706852 14th Dec 2024 2:07pm
RobsterPC
After a couple of drives in the dark I can report that the dipped lights work well but the high beams are amazing! Proper floodlights and so much safer for driving on dark country roads. Hopefully they last well, so far I'd massively recommend them.
Post #706888 14th Dec 2024 10:13pm
Scouse Exile
Out of interest, exactly which items did you buy as the Benvinsee ones seem to have options for 150w and 120w
Also are the Xenarcs much different to stock?
Jon
Post #706891 14th Dec 2024 11:07pm
RobsterPC
I bought the Bevinsee V55 H7s:
https://a.aliexpress.com/_EHjM7Yg
If you order them, make sure you pick the H7 option, it's not foolproof, ask me how I know.
As I had Osrams before, I can't really say how they compare to stock. The lights are slightly brighter, probably as they're new.
Post #707000 15th Dec 2024 10:56pm
Scouse Exile
Thanks, might give them a try.
J
Post #707001 15th Dec 2024 11:03pm
RobsterPC
Fixed the broken heated seat air guide with a new one from eBay. Also replaced the driver's seat base foam. With a trip to the Alps coming up, having a comfy chair to do over one thousand miles in is going to be important.
Post #707769 28th Dec 2024 6:41pm
Page 3 of 5 <12345>
