![]() | Home > Technical (L405) > FBH - Timed |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
mine is super good, running for c. 25 mins and getting really warm inside. may be the switch over valve syndrome which affected the L322? |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536 ![]() ![]() |
OP, mine was exactly like yours, didn’t run for long (tested it at 8mins run time) and blew cold. I persevered with programming it to come on, on a few cold mornings and it gradually got better, now it is as intended. Not sure if they all just need a bit of use to get things ‘flowing’ properly Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 130 ![]() ![]() ![]() |
I believe it should run for 30 minutes. Unless another condition stops it early, such as low battery or low fuel. |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
I will try this evening. I will connect the battery charger (to make sure). I use it a few times during the year, so maybe it never clears as suggested.
So, with the battery on the charger, I ran the FBH to warm the car, and it ran for 30 minutes. The voltage is never high enough. I will try again in the next few days without the charger connected. SDV8 AB MY 2020
So I try this afternoon. So for me I only get timed heating. If the battery charger is connected. I replaced the battery a couple of years ago. It seems ok.
