Home > Technical (L322) > Faulty windscreen washer
Dessie
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Windscreen washer motor not getting power. Fuses are OK. Can anyone tell me are there any relays ? Any help would be appreciated. Thanks
Post #707438 22nd Dec 2024 2:47pm
Baltic Blue
Relay 17 P.
Full diagram and details in Workshop Manual, free to download from WIKI.
Happy Xmas
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #707441 22nd Dec 2024 3:10pm
Baltic Blue
Tip, if rear washer is working, swap it with relay18P to prove.
Post #707442 22nd Dec 2024 3:14pm
Dessie
Thanks for that Mike, unfortunately I can't locate 17p and 18p relays. Would you have any idea where they are in the vehicle?I have checked below the bonnet, behind the glovebox and the rear luggage space.Thanks Dessie
Post #708010 1st Jan 2025 5:21pm
mjdronfield
Might be easier to just access the pumps, as could be broken pump. It was on mine. Behind the bumper on passenger side front, pull the inner wheel arch back. You can swap pumps and electrical connectors to prove where the fault lies. The front and rear pumps are interchangeable. The 3rd one is the headlight washer pump.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #708015 1st Jan 2025 6:03pm
