![]() | Home > Technical (L322) > Faulty windscreen washer |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Relay 17 P.
Tip, if rear washer is working, swap it with relay18P to prove.
Dessie Member Since: 22 Dec 2024 Location: Antrim Posts: 2 ![]() ![]() ![]() |
Thanks for that Mike, unfortunately I can't locate 17p and 18p relays. Would you have any idea where they are in the vehicle?I have checked below the bonnet, behind the glovebox and the rear luggage space.Thanks Dessie |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
Might be easier to just access the pumps, as could be broken pump. It was on mine. Behind the bumper on passenger side front, pull the inner wheel arch back. You can swap pumps and electrical connectors to prove where the fault lies. The front and rear pumps are interchangeable. The 3rd one is the headlight washer pump.
