![]() | Home > Maintenance & Mods (L405) > Adding Timed Climate Using JLR SDD to 4.4 SDV8 |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1477 ![]() ![]() |
I have no idea what this (^) is but if your VSE came with a FBH then the timed climate feature should be available from the dash menu system as standard, otherwise how would you enable it? 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Starbuck88 Member Since: 30 Oct 2024 Location: UK Posts: 3 ![]() ![]() |
Hi,
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Just done this with the help of Fifthhorseman!
Ah, gotcha ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 36 ![]() ![]() ![]() |
If you had no idea what is this program about, better to keep away from using it logically as you can do unbelievable damage. If you have some experience in programming software and change of configuration file then it is easy job. !The must! Battery charger plugged to the car! Full access for sdd with seed generation password. |
