Home > Maintenance & Mods (L405) > Adding Timed Climate Using JLR SDD to 4.4 SDV8
Starbuck88
2014 Range Rover Vogue SE SDV8 Loire Blue
Hi All,
Hoping someone can help/point in the right direction.
I have the SDV8 with the FBH but I want to enable timed climate to pre-heat the cabin.
I bought SDD Version 164 with a Copy Mongoose Cable.
I have done a DTC read and clear and thats about as far as I can get. It's certainly nowhere near as intuitive as BMWS ISTA Software.
Many thanks in advance and kind regards.
Post #707952 31st Dec 2024 6:15pm
Rob99
I have no idea what this (^) is but if your VSE came with a FBH then the timed climate feature should be available from the dash menu system as standard, otherwise how would you enable it? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #707994 1st Jan 2025 12:22pm
Starbuck88
Hi,
SDD is the JLR diagnostic and programming software.
I’ve seen people code in other things and have seen people code in the timed climate using gap iid tool but not using SDD.
Kindest Regards
Post #707995 1st Jan 2025 12:36pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Just done this with the help of Fifthhorseman!
You need this kit and gap tool, took minutes to fit, unfortunately my pump is needing replaced! 2014 vogue se
Post #707996 1st Jan 2025 1:11pm
Rob99
Starbuck88 wrote:
Hi,
Ah, gotcha Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #707997 1st Jan 2025 1:29pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Re: Adding Timed Climate Using JLR SDD to 4.4 SDV8
Starbuck88 wrote:
Hi All,
If you had no idea what is this program about, better to keep away from using it logically as you can do unbelievable damage.
If you have some experience in programming software and change of configuration file then it is easy job.
!The must! Battery charger plugged to the car!
Full access for sdd with seed generation password.
Post #711374 8th Feb 2025 2:01pm
