![]() | Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Happy new year all!
So with help from fantastic forum member Pawl I have been able to conduct a pressure test on the power steering system.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 825 ![]() ![]() ![]() |
i am sure i have posted before that i have had power steering problems, and lately its got worse.
Yours sounds like an issue with the servotronic valve or BCM Knares.
i seem to have lost my power steering altogether now RR 2005 4.4 petrol
Have you looked at diagnostics to see if your BCM is outputting the correct pwm signal to the servotronic valve Knares?
interesting
Its fitted inline between the power steering pump and the high pressure hose to the rack.
manufactured 12/12/04
It should be under BCM (body control module)
some time ago, i came across a guy wrecking his RR, same year as mine, i bought a heap of control units off him, all i could find.
Have you only just fitted the replacement BCM?
So today I've spent hours out in the 'storm' removing the lower steering shaft to inspect the UJs.
