|  | Home > Technical (L322) > M62 WATER PUMP |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      |
 The fattie has (again) deveoped a leak from the water pump's base, where the body mates with the block, just under the bottom left bolt. Coolant seeps slowly forming a drop and finds its way down onto the PAS pump, then onto the undertray and eventually on the driveway overnight. Running the engine for a couple mnutes is enough to make the leak stop, as the metals expand. So the leak only happens with a stone-cold engine.
|  5th Jan 2025 11:42am |
| batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 209    | Last year I replaced the water pump as mine failed (seized and took the belts out with it), and while I was changing it thought I'd change to the lower temperature thermostat, as I wanted to lower the temperature (my OEM pump had a problem with the electric sensor too).
|  6th Jan 2025 3:48pm |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | Thanks
|  19th Jan 2025 11:04am |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | So after the entire week with my daily work commute and temperatures dropping as low as 2-3C overnight, I'm glad to observe no more leaks. Coolant level has also been stable. I really hope that was all... | ||
|  25th Jan 2025 7:09am |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | An update ro wrap this up:
|  2nd Jun 2025 8:23am |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626      | Duplicate; pls delete | ||
| Posting Rules
