Home > Technical (L322) > M62 WATER PUMP
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
M62 WATER PUMP
The fattie has (again) deveoped a leak from the water pump's base, where the body mates with the block, just under the bottom left bolt. Coolant seeps slowly forming a drop and finds its way down onto the PAS pump, then onto the undertray and eventually on the driveway overnight. Running the engine for a couple mnutes is enough to make the leak stop, as the metals expand. So the leak only happens with a stone-cold engine.
I had the exact same problem (only difference the leak was on the right side bottom) just a year ago and opted to replace the entire pump and thermostat so that I wouldn' t have to deal with those again, in the foreseeable future. Yet here we are again just a year and 30K km later.
I used a HEPU pump with a MAHLE thermostat but since the previous pump was also a relatively new HEPU I'm beginning to think they may be facing quality control issues. I also had a brand new MAHLE thermostat fail in its electrical heating circuitry! As far as I understand the aforesaid brands are OEM that's why I insisted going with them but now I'm considering other makes.
Since the leak is from the particular point and not the shaft, I could perhaps get away with just a gasket but the amount of work is all the same if not more, cleaning the surfaces to fit a used pump back... I've had that done before with the previous pump that ended up leakng and blamed it on the refitting.
I've used/fitted FEBI Bilstein PCV, washer pumps, Inlet manifold gaskets and even coolant with zero complaints. As I see FEBI Bilstein water pumps sit somewhere above average price-wise, at around 70 Eur with HEPU being the priciest at around 100 Eur.
On a related note, how does the 85 C thermostat mod affect the engine performance? since there would no longer be on-demand thermostat opening. I understand the lower temp arguably prolongs service life of the cooling system components but on the other hand, I'm reluctant to change the default configuration as it should be reliable if maintained properly.
Any suggestions and recommendations are welcome
Thank you
Post #708343 5th Jan 2025 12:42pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Last year I replaced the water pump as mine failed (seized and took the belts out with it), and while I was changing it thought I'd change to the lower temperature thermostat, as I wanted to lower the temperature (my OEM pump had a problem with the electric sensor too).
I'd probably look at taking yours off, cleaning everything up, replacing the gasket and seeing how you go, but if you do look at replacing I replaced my pump with this one:
https://www.island-4x4.co.uk/water-pump-02...37675.html
and the thermostat with this one:
https://www.buycarparts.co.uk/mahle-original/7815123
The running is great, engine warms up nice and quickly getting heat, and it doesn't smell hot after a drive in hot weather or sitting in traffic, so I assume it's keeping everything cooler than before, which is going o be good for the gearbox cooler too.
Cheers
Post #708461 6th Jan 2025 4:48pm
vs322
Thanks
Been too busy lately and the car didn't leak all these days, until this morning. I hadn't moved it since Friday and temperatures drop as low as 1-2C overnight. So I wasn't too surprised to find a small puddle of coolant underneath.
This time I took the undertray off and was able to reach the bottom left bolt and the leftmost one from the underneath with a wrench. The former took about 1/8 of a turn and the latter 1/4 of a turn with minimal force. Was unable to reach any other bolt so I guess I'll see how that works. I would prefer not to touch the cooling system at all if I don't absolutely have to (was perfect before this).
Post #709633 19th Jan 2025 12:04pm
vs322
So after the entire week with my daily work commute and temperatures dropping as low as 2-3C overnight, I'm glad to observe no more leaks. Coolant level has also been stable. I really hope that was all...
Post #710111 25th Jan 2025 8:09am
vs322
An update ro wrap this up:
A couple months later the leak returned from another point of the paper gasket. I booked the car with the garage and ordered a genuine gasket and o-rings. Turns out the Hepu gasket installed lacked the silicone bead on one side. In addition, although relatively new, the Hepu pump had developed a very pronounced radial play. So this time I opted for an SKF, which was the only available locally. This was my 2nd Hepu pump over the course of 3 years and I won't be buying from them again. Also, regardless of the pump you choose to install, ALWAYS opt for the GENUINE gasket and O-rings as the ones coming with the aftermarket pumps, are always subpar.
Post #718988 2nd Jun 2025 9:23am
vs322
Duplicate; pls delete
Post #718989 2nd Jun 2025 9:23am
