![]() | Home > Technical (L322) > Chains on a 5.0 Supercharged |
| MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 643
AFAIK The NA doesn't exist in the UK. In the SC the chains are a common fault after (say) 80k miles, but I suspect there are some out there that have somehow kept it together. Mike - MPx
| Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100
As with any RR service history is a must.
| AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 71
Supercharger coupling is something else to consider.
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
I replaced the timing chains along with all the guides, tensioners and VVT sprockets in 2022.
| TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 82
It's not the chain, or at least it wasn't for me. It's the aluminum prop/cylinder/post on the tensioner under the guide(s) that wear when they manage the guide rail.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
It's usually the tensioner, it doesn't have a hardened mating area, they can wear out fast.
