Home > Technical (L405) > Suspected oil cooler
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Out of interest what level of cover do you have with Warranty Wise? I currently have the 06/60 level and I am pretty sure the only thing they didn't cover when I had my oil cooler replaced was the engine oil although they did only cover 2.2 hours of labour. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #708627 8th Jan 2025 12:40pm
Ukandrewf
i have the 08/80 cover
yeah they don't cover liquids.
the garage showed me that an L405 with 4.4 Haynes pro gives 6.1 hours to fit with the oil partical filter, which this engine has.
Thanks
Andrew --
On my third Full Fat RR
Post #708629 8th Jan 2025 12:47pm
Calvey
United Kingdom 2016 Range Rover Vogue SE SDV6 Carpathian Grey
Andrew
I was reading the thread and saw you are from South Bucks. I have recently moved to the area with my L405 SDV8 2016 and wondered if you can recommend a garage? 2016 L405 SDV8 Vogue SE
2012 Range Rover TDV8 Westminster Santorini Black
Post #709813 21st Jan 2025 5:02pm
Ukandrewf
let me pm you Smile --
Post #709835 21st Jan 2025 8:46pm
Dolphinboy
Ukandrewf: look at the coolant lines that run to the rear heating they can leak through the jubilee clips that hold them - there is a thread on here about this but you will have to do a search
Post #709836 21st Jan 2025 8:47pm
Ukandrewf
thanks for the tip. It's all fixed now and roasting in the cab again Smile now all I have to do is argue with the warranty company about what is covered. --
Post #709844 21st Jan 2025 9:14pm
