Home > Technical (L322) > Gearbox on it's way out? |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 733 |
Interesting - Sorry I can't help, but I've had just the same experience. I'm not sure if it's revving more, but definitely louder. Again, not sure if it's the engine or the box difficult to explain the noise, bit like a 'whooosh' that gets louder with the revs building up. Does the FFRR have a viscous fan - could it be this in the hot weather? |
4th Jul 2011 4:54pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 220 |
More than likely. Can't help with the gearbox issue though, sorry. 2012 4.4 TDV8 Westminster 2007 3.6 TDV8 Vogue - gone! 2003 V8 HSE (LPG) - gone! 2018 F-Pace 25t Portfolio 1974 LR Series III Lightweight FFR 2014 BMW 640i Gran Coupe |
4th Jul 2011 5:09pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Hmm, sounds similar. I guess it could be the fan spinning up faster than normal. The extra noise could make the engine sound like it's revving higher I suppose. Just been for a swiftish journey, it didn't sound too bad until I stopped for some shopping then seemed to be louder on return journey. It is possible that while stationery the temp built up and caused the fan to kick in more on way back. I have booked it into an auto trans specialist to have it checked out on Wednesday, been meaning to have the box power flushed, so if everything is fine I will get that done whilst it's there. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
4th Jul 2011 5:39pm |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 |
Are you sure it's not the aircon working harder ? |
4th Jul 2011 5:53pm |
I hardly ever use air con. No longer FF owner but still interested. Present car Jaguar XE
4th Jul 2011 6:08pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34951 |
...dan ,da dan dan.... |
4th Jul 2011 6:11pm |
Eh? What am I missing here No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
4th Jul 2011 6:23pm |
member mr dan 1984 or something like that ,always says you must have your a/c on....some kind of dry/cold fetish me thinks.. |
4th Jul 2011 6:24pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
I just replaced mine at 73,000miles, definately torque converter extra rotational speed, indicated by higher Revs first indications of gearbox failure on the 5HP type anyway.
4th Jul 2011 6:42pm |
You're telling me what I don't want to hear . I was thinking something like this. I bought the car from an indie dealer with a basic warranty. Which my guess is won't cover stuff like this. If the auto guy confirms it's on it's way out I guess I will try to argue the point with the garage. Fingers crossed for Wednesday. No longer FF owner but still interested. Present car Jaguar XE
4th Jul 2011 6:49pm |
better to prepare you up front, try oil and filter change, but will only do a short term fix, recomment getting indie to meet you half way on parts and fit for free, car is to good to get rid for the sake of a gearbox. rob Current vehicles 4.2 SC FFRR RSE 2010- facelift Range Rover Evogue Dynamic Lux Gone Rejected RRS my14.5 nightmare Disco B4 XXV convert Freelander 06 SE 06 RFFRR 4.2 SC Vogue RSE Audi A8 4.2Tdi Quattro (hated with a vengence!!) 54 FFRR 2005 model V8 4.4 Cobra Variant 53 Mitsubishi Shogun V6 |
4th Jul 2011 6:56pm |
allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440 |
Try it stationary in P or N - if the "whoosh" builds with revs then its the viscous fan. Just had mine looked at for the same reason and thethermostat was fooked so was locking the fan on even though the engine was at normal operating temp. Should only kick in when above normal temp to prevent overheating. Only really noticed when it was getting warmer and window/sunroof was open.... Could've spent all spring driving around with a wierd sounding car - Sounded like a 747 taking off when the foot was down!! |
4th Jul 2011 7:10pm |
Sounds daft and will not seem to make sense but try lubricating the Gear Control linkage Mechanism under the car on the side of the box. Just spray with 3-in-one or WD40.
4th Jul 2011 8:05pm |
Thanks for the suggestion. Half a can of wd40 now dripping from the linkage - hey it's worth a try see how it goes tomorrow. No longer FF owner but still interested. Present car Jaguar XE
4th Jul 2011 8:22pm |
