![]() | Home > Maintenance & Mods (L322) > L322 5.0 SC Vibration under light acceleration |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
On the straight or on a bend, or both?
fullfatfearns Member Since: 07 Feb 2025 Location: Stoke on Trent Posts: 15 ![]() ![]() |
Hi Haylands,
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 37 ![]() ![]() |
Does it do it in every gear? May be related to the torque converter which can often cause juddering. My understanding is that gears 1-3 this will be worse, then 4th gear upwards it is locked. Search the forum and there's quite a bit of info on here, look for info from 'RRPhil' as the resident gearbox guru. Can normally feel it worse when going up an incline too.
Hi Parallel,
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
Welcome to the shudder club same thing has happened to me with my new purchase.
Please keep me updated with your progress Dave!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
When you're on the motorway, stick the cruise control on at 70 and see if the revs stay solid or if they fluctuate.
Thanks David, I’ll give this a try. If it turns out to be the same issue, is this something a typical garage could fix or would I be best off with a specialist? |
AlexTVR Member Since: 18 Dec 2023 Location: Gloucestershire Posts: 54 ![]() ![]() ![]() |
https://www.automatic-gearbox.co.uk/land-rover-gearboxes/
Let me know how you get on Alex - hopefully easily sorted for you.
Well bridge seal and tube seals replaced today dispite the on and off drizzle.
Thanks for the update Dave. Sorry to hear no immediate improvement but hope it settles down over time!
I was ready to rip the torque converter out of mine but did some tests with the IID tool and with the advice of RRPhil the gearbox guru I swapped the solenoids on mine.
Thanks for the insight! I’ll forward this information over to the bloke who’ll be taking a look at it in case it’s useful. Will keep updated here. Fingers crossed not the TC! |
